C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Speed Limiter??
Old 10-14-2022, 02:32 PM
SlowCyberGS
Cruising
SlowCyberGS's Avatar
Default Speed Limiter??
Posted this question in the tech section, but thought I'd try here as well
I have an issue that I cannot seem to find any information on. My car will not run past 140mph. Will redline in 1st, 2nd, 3rd, and in 4th it gets to 140 and just sputters and will not pull anymore, just falls flat. Tuner said tune is fine, he thinks maybe valve springs, but why wouldn't that affect it anywhere else? Traction is off, active handling is off. It feels like there's a governor on the fricken thing, but that makes zero sense. 2011 GS Auto, A&A, long tubes, meth, 20k miles, stock internals I was told but it does sound like it has a slight cam at idle so not real sure on that one. Plugs and wires were replaced with no change
Old 10-17-2022, 03:14 PM
06MonteSS
Supporting Vendor
06MonteSS's Avatar
factory stock speed limiter is much higher than 140... it's up around 190-195... so something else is up with your car bud....
Old 10-18-2022, 04:39 PM
Mike@DiabloSport
Supporting Vendor
Mike@DiabloSport's Avatar
You need to log it as it hits this limit so someone can see what is causing it.
To Speed Limiter??
Quick Reply: Speed Limiter??
