C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Hptuners now a nightmare
Old 06-04-2018, 05:30 PM
LSCHLEM
Support Corvetteforum!
LSCHLEM's Avatar
St. Jude Donor '08-'09-'10
Default Hptuners now a nightmare
I was using HPTUNERS on My c6 ls2 fron 2007 to 2014 with much success.
Now I'M trying to install it on my windows 8 laptop. At the beginning of the upload I get a message I need .NET FRAMEWORK ver 2 . I then tried
to download from microsoft and the machine goes into PDF. I then logged on to HPTUNERS web and all that had changed. I needed New USER AND PW. AND IT RECOGNIZED THE SERIAL ON MY DEVICE but wanted some APPLICATION NUMBER and I recognize no such thing. Any SUGGESTIONS WILL BE VERY MUCH APPRECIATED. LAST VER WAS BETA I uSED ON
MY DELL XP. WORKED FINE THEN. THANKS, LEON
Old 06-05-2018, 03:10 PM
sevinn
sevinn's Avatar
St. Jude Donor '14, '16
Search your email for emails from "support@hptuners.com." Assuming you haven't deleted the emails, you should have access to your application key from your email, otherwise you may need to contact support for them to retrieve your application key based on your serial.
Old 06-06-2018, 04:00 PM
jft69z
jft69z's Avatar
You have HPTuners installed on the old laptop still, or is it the same one upgraded to win 8?
Old 06-08-2018, 08:43 AM
IansInGarage
IansInGarage's Avatar
Im sure there support can work this out. Also if you updated a WinXP machine to Win8 I feel sorry for you. Also 8 is not a good operating system I’m sorry to report. Windows XP (don’t use not secure), Windows 7 and Windows 10 are the only decent stable OS from my professional career opinion.
Old 06-09-2018, 07:48 AM
LSCHLEM
LSCHLEM's Avatar
Default Change in laptop
Originally Posted by jft69z
you have hptuners installed on the old laptop still, or is it the same one upgraded to win 8?
the laptop i am using is a win8. I know many say its not like win 7. I agree . I had to get on to hp tuners site and re do
new passwords etc. The problem is the original disc wont
start installing until i install that framework .net. I will try the old machine now that i have new numbers from hptuners.
Thanks leon
Old 06-09-2018, 01:34 PM
jft69z
jft69z's Avatar
Thanks leon
What I was getting at was, if you have it loaded somewhere else, you can open either the VCM Scanner or the Editor, click on the 'Help" and then 'Suite Info" and get the application key from there. (this was in response to the part of your initial question regarding the 'application number' you were having a hard time locating.)
Old 07-02-2018, 03:24 AM
LSCHLEM
LSCHLEM's Avatar
Default Finally got all my numbers from hp tuners
Originally Posted by iansingarage
im sure there support can work this out. Also if you updated a winxp machine to win8 i feel sorry for you. Also 8 is not a good operating system i’m sorry to report. Windows xp (don’t use not secure), windows 7 and windows 10 are the only decent stable os from my professional career opinion.
i did go from win 8.1 to win 10. What a difference . I got all my numbers from hptuners and thought i should be ok to install . I still get the message framework
2.0 needed to install. My new laptop which has all usb ports and no 9 pin serial connector. Im sure the usb 2.0 & 3.0 should work fine but i'm not sure.
Old 07-02-2018, 08:44 AM
Sox-Fan
Sox-Fan's Avatar
Did you download the drivers from the download page and install them?
Old 07-02-2018, 12:12 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Why would you need a serial connector for HPTuners again?
Old 07-02-2018, 01:12 PM
Sox-Fan
Sox-Fan's Avatar
On the MPVI the serial cable connector goes to the OBD2 adapter, not to the laptop.
Old 07-02-2018, 01:21 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Yeah. That was my point. If you plug serial plug into your laptop you will fry something; it's def happened before. You can't run 12V into a serial port and expect it to work very well
Old 07-13-2018, 06:19 PM
froggy47
froggy47's Avatar
Default Suggest a forum for tech2 learning curve?
I'm getting a clone to use on my 2013 z, currently in limp mode due to me messing around with swps disconnect & running with no tp sensors. Those are other threads, look if you wish to see what I did.
LSS I am needing some tips on using the tech2 clone.
I have one now does not pass the 2 basic self tests either it's broken or it did not include the proper loopback connections (rs232) and the other one on the main cable.
Automated main PCB and VCI self tests. Not passing.
Noob on this sub forum.
So I really don't want to proceed until I have a tool the self tests ok.
I ordered another clone to try. Please don't make this into a thread about "buy the real one", ok?
Summary: Need suggestion on forum to help with tech 2, or is here ok?
Old 07-13-2018, 06:27 PM
Sox-Fan
Sox-Fan's Avatar
This thread is about HPTuners. The title is HPTuners. The Tech2 is not HPTuners and is nothing like it. You're tagging along in a thread that has zero all to do with your question and where nobody will see it. Perhaps you should create an entirely new thread with Tech2 in the title so that people who know about the Tech2 and can help you will see it and be able to answer you.
Old 07-14-2018, 02:49 AM
froggy47
froggy47's Avatar
Sorry to get you all upset. I tried to delete it. It didn't work.
Hope you never make a mistake like I did.
You get snarky reply's.
I did what you suggested, thanks for the great advice.
Old 07-14-2018, 08:10 AM
Sox-Fan
Sox-Fan's Avatar
Wasn't a snarky reply when I wrote it. Guess that's just what you heard in your head. I can't help what goes on in there. Glad that I could help though.
Old 07-14-2018, 01:56 PM
froggy47
froggy47's Avatar
LOL, you are a funny guy, So "I can't help what goes on in there" is not snarky? Whatever. Just so you know, I have a quirky sense of humor too. To be clear, I reposted my question properly HOURS before your "help" came along. So my sense of humor tends to dry sarcasm rather than snarky.
So let's shake on it and put good info out re: the cars we love. OK?
Old 08-08-2018, 08:49 PM
LSCHLEM
LSCHLEM's Avatar
Default Mpv1 hookup
I was not trying to get 12Vdc into my computer port. I know better. What I have is The plug on the HPTUNERS BOX goes to the OBDT Connector on the car. The other side of the box has a ethernet plug and that has a USB connector on the other end for the computer. I had to get a new APPLICATION KEY and I have all applicable numbers now I will try to install it tomorrow and see what happens. I also have WIN 10 much better THANKS
To Hptuners now a nightmare
Old 08-10-2019, 08:47 AM
LSCHLEM
LSCHLEM's Avatar
ORIGINALLY I HAD HP TUNERS MPV1 AND THE LAST SOFTWARE UPDATE WAS TO BETA 2.3. I KNOW THERE HAS BEEN SEVERAL RELEASES SINCE THEN.
IT GOES BACK TO 2008. NOW I HAVE a NEW LAPTOP WITH WIN 10. I TRIED TO INSTALL HP TUNERS DISC AND I GET A MESSAGE TELLING ME I NEED
.NET FRAMEWORK 2.0. I TRIED TO INSTALL MANY VERSIONS BUT THEY WONT INSTALL. THE OLD DELL HAD A 32 BUS and the NEW IS A 64. I HAVE BEEN TRYING WITH THIS INSTALLATION FOR SOME TIME. ON MONDAY I WILL HAVE SOMEONE ELSE INSTALL.
I HAVE A GREAT TUNE. PROBLEM IS IT WANTS TO STALL ON DECEL. ITS DANGEROUS TO DRIVE LIKE THIS. WOT ISN'T EVERYTHING. I GOT 500+ RW
AND I NEED TO SOLVE THIS PROBLEM. ANY COMMENTS
Old 08-10-2019, 01:32 PM
froggy47
froggy47's Avatar
You need to get an old laptop with windows 7 or earlier. A lot of automotive software does not "like" the newer windows.
I always save an old laptop or 2 just for this.
Old 08-10-2019, 09:32 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
That is not true.. It works fine on Windows 10. Install the framework it mentions as required, install the correct drivers and install VCM suite and it will work.
Blizzard1975 (08-22-2019)
Quick Reply: Hptuners now a nightmare
