Changing Rev limit on A6 - Any issues?
I'm about to install some Headers, Tunnel plate, and get a Tune on a 13' GS A6. I've noticed when reving the engine in Park or neutral it kicks out at 4k.
I was reading (True or False...) that with the M6 the Rev limiter is set much higher at 6500rpm.
So to my question:
Would raising the Rev limit to 6500 (and or Reving it to that in Park) cause and damage and is there any reason to NOT attempt this?
So to my question:
For what purpose would you want to rev the motor that high for in neutral ??
It already should be shifting at pretty close to the red line if you have an A6
When you stomp on the pedal at what RPM does the motor shift into 2nd ? ... I bet its real close to the red line if not right on it
Dave
Received 1,194 Likes
St. Jude Donor '15
Because it's super cool guys, come on
St. Jude Donor '13-'14-'15
The 4000 rev limit is usually used when the eng in COLD or below operating temperatures--revving it up beyond 4k is just plain stupid !!!let the rice burners rev their engine up to 6k when cold- who cares if you blow up a $1500 car----
Now if you are serious about raising the rev limiter after warmed---The only advantage would be if you raise the SHIFT POINT RPM's There are 2 RPM limits
on an A6 ---the 1st limit is the "shift at RPM limit" and the 2nd is the "safety rev limiter"
The only time you should alter the shift point RPM's is IF you install a cam where your powerband goes higher than stock otherwise there is NO advantage to rev of a stock cammed engine beyond 6000 RPM's as above that it actually starts making LESS HP
Ideally you want the shift to happen at "peak HP" and after shifting you don't want the RPM's to drop below "peak TQ" so a stock cammed engine it set spot on as far as shift RPM's is concerned----
So to my question:
So to my question:
