C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
91 or 93
Old 07-28-2014, 06:53 PM
dazz44
dazz44's Avatar
Default 91 or 93
Question I just purchase a Diablo sport predator...I live in Texas and I run 93 but my tune states 91 when I was installing it. Is there a way I can change it to 93 or is 91 about the same. Help
Old 07-29-2014, 09:27 AM
t.renz791
t.renz791's Avatar
If it were me, I would use the 91 tune, and run 93 octane fuel for safety, especially with the heat down there.
Old 07-29-2014, 11:09 AM
dazz44
dazz44's Avatar
Thanks.... will do.
Old 07-29-2014, 01:00 PM
C7/Z06 Man
C7/Z06 Man's Avatar
The DiabloSport tune is the 93 octane tune. So load the DS tune if you want the 93 tune.
Old 07-29-2014, 01:29 PM
dazz44
dazz44's Avatar
My DiabloSport tune only flashes 91 not 93. Is there a way I can pull up 93.
Old 07-29-2014, 04:07 PM
C7/Z06 Man
C7/Z06 Man's Avatar
The Predator will ask you on the screen if you want to load the 91 octane tune or the DiabloSport tune (maybe it's called the Predator tune? but I think not iirc) which "is" the 93 octane tune; so select that tune to load if you want the 93 octane tune. What year car and model Predator; try reviewing your directions or go to their website for info.
Old 07-29-2014, 04:19 PM
Mike@DiabloSport
Supporting Vendor
Mike@DiabloSport's Avatar
Yep, the 93 tune is the Diablo tune in the list
Old 08-04-2014, 03:26 PM
t.renz791
t.renz791's Avatar
I have an 09 Z51, stick that I just got, first domestic car in years. I have my 2006 330i tuned- the company sent me a tool to pull the stock tune, email it to them, and send back a modified tune. It works well, part throttle as well as WOT.
Does the Diablo off the shelf tune alter part throttle, or just wot? Does it change the redline?
Old 08-01-2015, 10:37 PM
Columbia Corvette
Columbia Corvette's Avatar
Default Trinity tune
So guys, if the Diablosport tune is the 93 octane tune for the Predator, is it also the 93 octane for the Trinity?
Old 08-02-2015, 09:08 AM
Z0HS1CK
Z0HS1CK's Avatar
Received 3,186 Likes on 2,136 Posts
Yes.
93 octane is 93 octane.
Just make sure the device whatever you have, is full updated.
Old 08-11-2015, 01:19 AM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
In calif we only have 91 oct fuel From what I've learned and read these new DI engines are NOT as octane sensitive as previous LS engines---I know many local C7 owners that that run the 93 octane tune even though we only have 91 and are having "0" detonation or KR
Old 08-11-2015, 02:49 PM
JoshBarber
JoshBarber's Avatar
I ran the DiabloSport tune (93 octane) for a while this year, and I am in DFW, so the tune works fine. I found running the DiabloSport tune and pumping 93 I got a marginal MPG gain of around 0.4 MPG (it adds up!).
I would recommend trying the Diablo tune for a while, and then if you think you could use a little more grunt, try a custom tune.
To 91 or 93
Quick Reply: 91 or 93
