Tuner Error???
Tuner Error???
Question: Is it possible for a tuner to make an error re scaling an injector table with EFI Live to cause one injector to be commanded wide open when the key is turned on and fill a cylinder with fuel causing a hydro lock? The result was that the starter was literally blown right off the side of the block. (starter destroyed and a chunk of the mounting boss sheared off the block) Or was it just a faulty injector.(Although I cannot yet determine the injector was at fault, it seems to be fine.......but i'll know for sure tomorrow when all 8 injectors will go on an ASNU machine for testing)
Tuner Error????
There is no individual injector control so I would say no. The settings would affect all 8 injectors.
Thank You!
Thanks for responding to my post. I did not think it was possible to scale the injectors individually......but was not completely sure. The suspect injector has now been carefully pressure and pulse tested and is working normally. Guess the "stuck open" issue was intermittent as that condition cannot be replicated. ( I'm sure that makes my destroyed starter and damaged block feel better.....or not!)
Hydro lock
As strange as it may sound to some people, I'm here to inform you that it can and does happen!!When even 1 piston comes up against liquid greater in volume than the combustion chamber the piston WILL stop. The hi torque starter is powerful enough the break away when engaged with the flywheel ring gear. First the inner mount breaks (starter end piece) and then the wimpy boss on the block breaks. Guaranteed EVERY time!!!Try pouring a pint of ANY liquid in ANY cylinder, put the spark plug back in and hit the key. If will become a LOT less strange.
RE: Engine is fine and suffered no consequential damage. Fortunately the # 5 rod was tougher than the poorly designed starter and it's weak crappy mount.I have read on this forum that installing the newer design ( 2 long bolt starter) will be a more reliable setup. Ironically I read that just a few weeks ago.
