Is my wideband that far off?
Use the current last know LTFT at the RPM or MAF value or whatever. So if you have +10% from 6000hz to 12000hz from cruising around, and you punch it it will add 10%. This isn't a theory, it has been known for a LONG time. The GM ecus have behaved that way since 97 or earlier.
Sounds like your VE maps is off, or you have some other multiplied messing with fuel. COT off? What OS are you running? Could be BE taking over if you are running the 2.5 bar os.
I do run a 2.5 OS but I've disabled COT and BE. Still need to figure out IVT Gain effects fueling but that will be next. Thanks
You would be surprised. Most tuners just get it going and ship it out. Very few good ones out there. Correct injector data? AHahah, most don't care. Just dial in the PE and timing until the car makes power, make sure it idles and ship it.
