DiabloSport Intune Buying Question
Does anyone know if a Model I-1000 for a 2002 Trans Am LS1 would also work for 2006 C6 base model?.
TIA
TIA
I-TUNE1000 just updated it, plugged it in....used 91 octane tune and firm tcu shift instead of hard and noticed the difference right away on w.o.t......2nd gear chirps that werent there before....
thanks,
mike
thanks,
mike
Supporting Vendor
__________________
Mike Litsch
DiabloSport/Range Brand Manager at Holley
Trinity T2 and inTune i3 now available for 99-19 Vettes!!
Subscribe to our YouTube Channel!
Mike Litsch
Cruising
Mike I am looking at a Diablo for my 2005 C6. I have added Varaam cold intake, Corse Y pipe and Corsa Extreme exhaust. Will the Diablo give me more performance and which model do you suggest. Stock LS2
Supporting Vendor
The intune will work perfectly well for you and wake that LS2 up nicely.
diablosport intune
don, i just retuned to diablo 93 octane tune instead of 91 octane with my intune diablosport i2000 and i have a 05 ls2....you will not be disappointed.it woke up my ls2 and feels like the ls3 i just sold for a 400.00 investment you cant go wrong!!!the 91 octane tune chirped the tires in 2nd gear!
Cruising
I will try it . So far I am very disappointed in teh unit T-1000 and I am very disappointed in their support.
Supporting Vendor
Don, I have done my best to answer your every question, respond to all PMs, emails, and posts here. I get that you don't seem to be pleased with the tune, but I have done everything I can think of to assist you along the way, and it burns me to see you complaining about our support.
I doubt there are many other manufacturers checking these forums on a Saturday evening, but I like to make sure there are no unanswered questions out here. I like to think that's an above and beyond level of support.
Please, as mentioned in my email yesterday, feel free to email me directly anytime you need anything. I check my email several times a day, even when I am not in the office, since as you can see, I pride myself on the level of support provided.
Considering you are not seeing the typical results reported by most all other users here, it might be a good idea to check the car out, make sure the plugs are good, no cracked plug wires, etc, and then try the tune again.
Don, I am also using the 93 octane tune on my 06. While it took about 100 miles to settle in, the results have been obvious. I am also working with DiabLew to further modify the tune and that has made even more improvements. Work with Mike... He won't do you wrong! He has a great product and if you aren't seeing positive improvements, I would really look to see if there is an underlying issue with the car. Just my two cents!
The removal of torque management and the other map changes made the car so much more enjoyable to drive. I would recommend DiabloSport to anyone. I would give them another chance-something is not correct-I have spent ALOT more and got ALOT less. Mike is a good guy.
I am absolutely shocked by your statement. I purchased an Intune and programmed the 93 Diablo tune in my 13 Grand Sport Coupe w/6sp., it was IMMEDIATELY apparent that the tune changed the cars performance. I was so pleased that I emailed Mike and he responded to me the same day. Any questions I had were answered. The product ,at least in my opinion, has exceeded ALL my expectations.
