need help: auto transmission!!!
Hwy guys.
I went to repark My 08 c6 automatic and it wont go into any gears including park. The shifter moves freely up and down all gears but wont engage any gear. It wont even go into park, i put it in park and it rolls back!!
sounds like the shifter linkage is broken either at the shifter or the tranny. do a search as I believe another member replaced his cable. if you're mechanically inclined you can replace it yourself.
good luck!
good luck!
