data logging afr w/intune?
did some data logging and I have a few questions..does the intune have data logging capabilities for air fuel ratio or do I need a wideband o2 to do so? I only see the pids for short and long term fuel trims. when reading the data logs how do I check the afr mixture at idle and wot? does it even have the capabilities to display narrow band voltage?
thanks
thanks
Supporting Vendor
yes it does.. it's in there.. called Equivalence Ratio...
and the default parameters selected for logging, log more than those fuel trims.. you have to scroll down to see all the rest... it has about 14-16 pid's preselected already to log... you will have to add the Equivalence Ratio one...
you can find the info/instructions for doing a data log on my site www.diablewtune.com at #5 for the inTune...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
and for the default parameters selected for logging, log more than those fuel trims.. you have to scroll down to see all the rest... it has about 14-16 pid's preselected already to log... you will have to add the Equivalence Ratio one...
