long tube headers/FAST intake w/Intune?
anyone running long tube headers, FAST intake with an diablo sport Intune 93 or custom tune? i'm trying to determine if the Intune with a custom tune will get the job done or if a dyno tune is needed. anyone got first hand knowledge and/or results?
thanks
thanks
From what I've heard you gotta go with a dyno with that set-up. Once LT's are used it's dyno time, especially with FAST.
Supporting Vendor
nah.. I can definitely get you hooked up with an inTune + custom tune for your setup, no problem... www.diablewtune.com
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
My where the rubber meets the road "real world" experience with "Intune".
If you check the C6 GS "bolt-on" fast list you will see with headers, cai and an intune "canned" 93 tune with tires I hold the bolt-on record big time.
Second & third place are running similar stuff, but most likely of higher price and quality along with dyno tunes. What else needs to be said except a "custom" DiabloSport tune maybe even better.
You may say to yourself that is a small sample, well if you look at the lighter regular/narrow body LS3 "bolt-on" fast list you will see that they are slower too! running the "same" type of mods.
Bottom Line: It's the tune! and the track will always tell the story.
PS: I love "Kicking A$$" don't you.
But wait, I just checked the C7 "bolt-on" list and it even gets better. The two C7's are stick, however one still has a much better 60 ft. than me yet both are way down on mph (hp) and I have a better et. WOW
I have an OEM air intake assembly that receives cold air and my understanding is that the C7 OEM set-up receives cold air too.
Supporting Vendor
