coloradoSPEED offering remote tuning with HP Tuners! (not copy and paste)
Been researching tuners and came across this thread. I will am going to be purchasing a modified vette, ie supercharged or with most supporting bolt ons, ie I/H/C/E and have it shipped to me in Parker, CO. I'm actually located about a mile from your location at Main Street and Jordan and was hoping you guys could road tune my car for altitude and atmospheric pressure. Given this scenario would I still need to purchase the HP Tuners software/ obd2 cable?
We will pm you with details a bit later!
So, with the following mods, would this require a in person visit, or can it be remotely tuned?
NOVI 1500 Supercharger kit
Dual nozzle alky-control
Lethal Racing Mild Cam kit
A&A Stage 1 fuel kit
RPM level X trans
RPM stage 4 diff
Im about the get the engine forged and cut to a 408 so I can remove the restrictor plate in the ECS kit.
RPM level X trans
RPM stage 4 diff
RPM level X trans
RPM stage 4 diff
RPM level X trans
RPM stage 4 diff
Can you remote tune any place in the world with Internet?
We can do SD tunes as well.
As far as ATLS2, i am not sure i would pulley down too much. Belt slip can be bad. using a bigger crank pulley is a way around that and itll drive the accy faster. But dont run too may rpm or you will just turn your supercharger into a heat pump. Then the alky wont help at all.
I can and have remote tuned cars in canada and overseas a few times yes. As long as you can follow directions, give me good feedback, and follow a set path, we are good!
