Every Tech should have this LS Timing cover Alignment Tool!
Supporting Vendor
AlignIt Tools are to designed to align the Timing Cover & Rear Main Cover and install the Seals on all LS base engines.
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 Timing and Rear Main cover and seals. Works with all LS based engines!
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Buy more than one of the AlignIt Tools and save!
http://www.saccitycorvette.com/AlignItTools.html
Here is a video that shows how simple it is to use. Tools used in videos are prototypes. The tools we sell are much nicer!
Installation with Oil Pan off.
SacCityCorvette LS1 2 3 6 7 timing cover tool. - YouTube
Here is a Video the shows installation of Rear Main cover and seal with the Oil Pan on.
AlignIt Rear Main Cover Tool - YouTube
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
The AlignIt, aligns the timing cover with the crank in seconds and then makes installing the seal easy!
Supporting Vendor
These tools ensure alignment accuracy and time savings!
Supporting Vendor
The Hub Simulator Tool is for those that do not want to remove the seal.
It simulates using your hub to align the timing cover with the seal in place.
Supporting Vendor
The AlignIt tools get the covers centered perfectly with the crank and install the seal in seconds.
Former Vendor
AlignIt is a LS Timing Cover & Rear Main Cover Alignment Tool and Seal Installer!
easy work of installing your LS1-2-3-6-7-9 Timing and Rear Main cover and seals.
Timing Cover AlignIt Only $26.95
Rear Main AlignIt Only $37.95
Hub simulator only $23.95
http://www.saccitycorvette.com/Timin...nmenttool.html
AlignIt Rear Main Tool. Only $37.95
Front & Rear AlignIt Kit. Save 10% Only $58.41
We use these during our LSx engine cam swaps, timing chain replacements, and lifter/pushrod changes and these are very useful to have! When you're working with the engine in the car still one of these will consistently save about 10 to 20 minutes on the build process if you're replacing the front seal (we replace the FMS every time the timing chain cover is removed).
We recommend these without reservation to anyone who is doing a cam swap with the engine still on the vehicle and is replacing the FMS.
Thanks,
Andrew@TRIFECTA
Supporting Vendor
Thank you Andrew for your Business and the good word about the AlignIt Tools!
Christian
Christian
Supporting Vendor
Planning a cam swap or engine rebuild? AlignIt Tools can help with the rear main, timing cover and seal install. And get it done right the first time with less chance of leaks!
I can vouch. Always did it the hard way before. Bought one to try on my recent cam swap, and it worked perfectly. Much easier than trying to use a damper to align the cover not to mention a good seal installer. Nice to have a well thought out tool without the usual Corvette tax. Shipped quickly also. Thanks guys.
Jackcloud (09-12-2016)
Supporting Vendor
Here is a simple but very effective tool to help you make easy work of aligning your LS1-2-3-6-7-9 Timing Cover, Rear Main Cover. They even install the seals.
