C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Dashcommand Experiences/Opinions?
Old 01-24-2013, 12:20 PM
JerzeyDevil
JerzeyDevil's Avatar
St. Jude Donor '09-'13
Default Dashcommand Experiences/Opinions?
I tried searching but couldn't really find much. Does anyone have any experiences or opinions on dashcommand?
Old 03-11-2014, 12:38 PM
Ellison489
Cruising
Ellison489's Avatar
http://forums.corvetteforum.com/c5-g...-a-gander.html
A lot of text but the pictures do some justice and you CAN hook up an external afr, ait, fluid temp, and egt the need to be the plx imfd modules though im in the process of updating my write up
Old 03-12-2014, 02:17 PM
0PalmerPerformance
Former Vendor
PalmerPerformance's Avatar
If you have any specific questions, we can help you out as we are the developer of that application.
Old 07-03-2014, 10:23 AM
bjmsam
bjmsam's Avatar
Can DashCommand be fully controlled via a touchscreen headunit? At 10:40 in
, some things worked while others did not, but perhaps the connectivity was not as suggested. Do some HUs work better than others? Does Wi-Fi work better than Bluetooth? Is a Windows Phone 8 version available? Does it work with DashLogic?
Old 07-07-2014, 04:10 PM
0PalmerPerformance
Former Vendor
Originally Posted by bjmsam
Can DashCommand be fully controlled via a touchscreen headunit? At 10:40 in this video, some things worked while others did not, but perhaps the connectivity was not as suggested. Do some HUs work better than others? Does Wi-Fi work better than Bluetooth? Is a Windows Phone 8 version available? Does it work with DashLogic?
We can connect on the JVC, Pioneer, and Clarion head units that allow the app modes.
Old 07-07-2014, 05:55 PM
bjmsam
bjmsam's Avatar
I hope it works on the Android head unit I just ordered.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=191227453040
Old 07-27-2014, 07:54 PM
bjmsam
bjmsam's Avatar
Results (from my installation thread):
DashCommand works, too.
...except for the Skid Pad, perhaps because the car's accelerometers are inaccessible via the OBD2 port?
Old 07-28-2014, 01:16 PM
0PalmerPerformance
Former Vendor
The Skid Pad uses the device internal accelerometer. It appears your stereo does not have accelerometers inside?
Old 07-30-2014, 06:05 PM
bjmsam
bjmsam's Avatar
Apparently not. I suppose handheld devices have accelerometers primarily to detect display rotation, which is obviously not a factor for a fixed display mounted in the dash, but inconvenient considering the Vette's accelerometers are inaccessible via OBD2. Bummer!
Old 07-06-2015, 09:24 PM
wSc*daywalker
wSc*daywalker's Avatar
Hi, i have a avh-p4300 pioneer DVD radio in combination with an iPhone 4 via the usb connection connected and I don't get the dash command on the screen. Any particular setting I need to choose? I have an iPod mode where I can select app mode. Thank you!
To Dashcommand Experiences/Opinions?
Quick Reply: Dashcommand Experiences/Opinions?
