Tech2 Codes C0035 0F -- What do the last two characters mean?
I had the Chevy dealer read out a some codes using a Tech2 on my 2006 C6. I know how to decode the first letter and next four numbers, but what do the last two characters mean?
C0035 0F
C = Chassis
0035 = Left Front Wheel Speed Sensor Circ
0F = ????
C0186 19
C = Chassis
0186 = Lateral Accelerometer Circ
19 = ????
Thanks.
C0035 0F
C = Chassis
0F = ????
C0186 19
C = Chassis
19 = ????
Thanks.
Received 8,929 Likes
C0035 0F
C = Chassis
0F = ????
C0186 19
C = Chassis
19 = ????
Thanks.
C0035 0F
C = Chassis
0F = ????
C0186 19
C = Chassis
19 = ????
Thanks.
DTC C0035 00 : Left Front Wheel Speed Sensor Circuit
DTC C0035 0F : Left Front Wheel Speed Sensor Circuit Erratic Signal
DTC C0035 18 : Left Front Wheel Speed Sensor Circuit Signal Amplitude Less Than Minimum
DTC C0040 00 : Right Front Wheel Speed Sensor Circuit
DTC C0040 0F : Right Front Wheel Speed Sensor Circuit Erratic Signal
DTC C0040 18 : Right Front Wheel Speed Sensor Circuit Signal Amplitude Less Than Minimum
DTC C0045 00 : Left Rear Wheel Speed Sensor Circuit
DTC C0045 0F : Left Rear Wheel Speed Sensor Circuit Erratic Signal
DTC C0045 18 : Left Rear Wheel Speed Sensor Circuit Signal Amplitude Less Than Minimum
DTC C0050 00 : Right Rear Wheel Speed Sensor Circuit
DTC C0050 0F : Right Rear Wheel Speed Sensor Circuit Erratic Signal
DTC C0050 18 : Right Rear Wheel Speed Sensor Circuit Signal Amplitude Less Than Minimum
DTC Descriptor
DTC C0186 00: Lateral Accelerometer Circuit
DTC C0186 08: Lateral Accelerometer Circuit Signal Invalid
DTC C0186 09: Lateral Accelerometer Circuit Rate of Change Above Threshold
DTC C0186 19: Lateral Accelerometer Circuit Signal Amplitude Above Maximum
DTC C0186 1A: Lateral Accelerometer Circuit Bias Level Out Of Range
DTC C0186 52: Lateral Accelerometer Circuit Compare Failure
Bill
bo_knows (01-05-2019)
Cruising
Hi Bill,
Thank you very much for posting the procedure! Is there a way for you to post the page that shows where to probe for voltage?
Documentation is referencing certain points.
Thanks,
Bo
Thanks,
Bo
