Check engine light!
Check engine light!
need help with engine codes.
P0161
P0155
P0141
P0135
P0060
P0059
P0056
P0054
P0053
P0050
P0036
P0030
P0154
P0134
has anyone had the same problem, any advise. i know thy are related to the O2 sensors. thanks.
P0161
P0155
P0141
P0135
P0060
P0059
P0056
P0054
P0053
P0050
P0036
P0030
P0154
P0134
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,831 Likes
2015 C7 of the Year Finalist
Mods? Headers? If all are O2, did you burn a wire or is it disconnected?
first is bank 2 sensor 2, 2nd one is bank 2 sensor 1, then bank 1 sensor 2, then bank 1 sensor 1.????
What did you do?
Elmer
What did you do?
Elmer
not to sure what modification it has, the previous owner said it has a ZO6 conversion, im the 3rd owner. from what i can see it has SLP Power flow exhaust. im taking it to the shop this weekend and take a look under.
Well, your codes refer to all 4 sensors. Usually it is pissed at the rear 2 or the 2 right side or the 2 left side but to be upset about all 4 is very unusual. If you cannot list the modifications, the shop might be your best recourse to discover what is going on.
Elmer
Elmer
O2
Looking at the schematic for the o2 sensor, there are two things in common to all the o2 sensors, the ecm and fuse 6. Fuse 6 is located in the underhood fuse block, it is marked as o2 sensor and is a 15 amp mini fuse.
well today was a goo day!!! checked the fuse and it was not blown but it was 20 amps instead of 15 amps. replaced it and today the light is gone, also got my TIPS tool in the mail and reset the tire sensors.
