New intake and exhaust, should I get it tuned?
OK
Added a Vararam, and am about to add some B&B bullets to the car. My question is, should I take the time to get a tune on it or is just intake/exhaust not enough to warrant the expense?
Also, where in Northern IL should I go to get the work done?
And lastly, about how much should I expect to pay?
Thanks much!
Mike
Thanks much!
Mike
Yes, you should get the tune to take full advantage of your bolt-on mods.... in fact, the tune alone will give you as much improvement as the hardware you've installed.
I suspect that most reputable tunes will cost in the $200-$400 range.
Good Luck!
Good Luck!
St. Jude Donor '11, '13
Diy???
I see I can buy a gismo and do my own tune??
http://www.hypertech.com/products-max-energy.aspx
A capable vette experienced tuner, compared to this gizmo? Stupid question but I'm new here, this is my first vette....
Good Luck!
Good Luck!
And NO. Don't buy a generic gizmo to do your tune for you automatically!!
Take it to a tuner that has access to a dyno!
OK
Thanks much!
Mike
Thanks much!
Mike
