Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2009, 03:03 AM   #1
satans csex
CF Senior Member
Support Corvetteforum!
satans csex's Avatar
Default Rhs/warhawk 454 build...finished!
Alright Guys..... I am back again with some great results!
I received my motor on 11/06/09 at 5 p.m pulled an all nighter and had her running at 11/07/09 6:15 a.m. After so much hard work and time spent on my car "Satans Zo6" is back to life! I got to drive her home at 5 P.M after finishing all my customers cars... as promised
Details :
I tried my best to work out that RHS Block but it just did not fit my time period! After 3 weeks of hearing we will receive the block this week I decided to go with the Warhawk...... I Like High revs and as I said this has to be a "budget Build", so we went with the short deck "454" end results were Incredible...although I did run out of Fuel Injectors "max Duty" and MAF Sensor...BUZZ KILL! Car maxed out at 593 RWHP and 535 TQ...... I was also running cats! She asks for more fuel starting at 5700 rpm so we know these numbers will be much higher once everything is complete I will replace the MAF sensor and the fuel Injectors as well as knock out the stuffed cats! I will need a 102 ported fast as well since I am not getting enough air in :/ . The car is also on the smaller ... "More streetable cam" which cost me a 40 Hp drop to the flywheel..... She is incredibly FAST!!
Special thanks :
I would Like to thank Chad @ "Golen Engine" Man behind his word! Also the man that covered 2 cam swaps and ate the cost of them because he wanted to go the extra mile as I like to do my self and only work with those who do!
I would Also like to thank Mike and Tad @ "Haddad Motor Sports" For taking their time and putting in that fine tune! Thanks for the colder plugs MIKE! "GIFT"
Specs:
1.Warhawk block
2.Magnum crank
3.Diamond "coated" Pistons & upgraded Pins and oilers 12:1
4.Callies I beam rods
5.Custom Billet Camshaft
6.Ported LS7 Heads,Intake Manifold, and TB
7.Aviad windage tray & tank insert
8.RPS STREET TWIN LIGHT
9.Aluminum Torque Tube Bushings
10.Talent Motor Sports Built Transmission
11.Strengthened out put shafts for the differential
12.Heat wrapped Kooks 1 7/8 Headers, catted X pipes and stock Zo6 exhaust with "Muffler Mod"
SLIDE SHOW :
I will be back on this post Hopefully soon.....I unfortunately am Only 19 with Bills over your head and am not made out of money or have parents supporting my build so i will try my best to get back with the Maf since Joel has supported me with Injectors.... I would also like to thank this man ....... Until then hang in tight for higher Numbers expected Once N/A Set up is complete...........We will then introduce a nice Nano Nitrous System to "Satans Zo6" and watch her our competitors and run around them and then at them and tell them they have chance and make me look and now im about to "ROLL OUT" ENJOY
satans csex is offline   Reply With Quote
Old 11-20-2009, 10:13 AM   #2
redhardsupra
Junior Member
Send a message via AIM to redhardsupra Send a message via Yahoo to redhardsupra Send a message via Skype™ to redhardsupra
which maf and which injectors did you run out of ?
redhardsupra is offline   Reply With Quote
Old 11-20-2009, 01:01 PM   #3
satans csex
CF Senior Member
Stockers
Reload this Page Rhs/warhawk 454 build...finished!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
