Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-11-2009, 11:18 AM   #1
WhiteLightning_
CF Senior Member
Default Wideband lc1 vs ngk
any pros/cons with one over the other? i cant seem to find any direct comparison between the 2..
thanks in advance.
WhiteLightning_ is online now   Reply With Quote
Old 11-11-2009, 12:10 PM   #2
DSteck
CF Senior Member
DSteck's Avatar
Send a message via AIM to DSteck
The LC-1 is nice because it's fully programmable, and you can specify the output range, which helps when developing a correct transfer function. The NGK is said to be more accurate, though.
__________________
Forged 427 LSX, WCCH LSX-LS7 heads, TTix 6265 kit, HoB Aeromotive Eliminator fuel system, RPS BC3 clutch, RKT56 TR6060
CBI Built, DSX Tuned
Injector Dynamics snob
DSteck is offline   Reply With Quote
Old 11-23-2009, 08:46 PM   #3
turboffr
CF Senior Member
St. Jude Donor '10
turboffr's Avatar
NGK all the way
turboffr is offline   Reply With Quote
Old 11-23-2009, 11:24 PM   #4
TurboLX
CF Senior Member
Unless you're a cheapskate whose only criteria for selecting a wideband is price and price alone, there is no comparison here. Get the NGK AFX.
__________________
Greg Banish
Calibrated Success, Inc.
TurboLX is offline   Reply With Quote
Old 11-24-2009, 02:06 AM   #5
thesubfloor
CF Senior Member
thesubfloor's Avatar
Location: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Quote:
thanks in advance.
The LC1 is a total POS. Do a search on the HP Tuners forum and you'll see tons of complaints about it. I've had my NGK for about two years now and have never had any issues with it and I also pull it out of my car frequently to tune other people's cars - it really is that easy to wire up properly.
thesubfloor is offline   Reply With Quote
Old 11-24-2009, 12:47 PM   #6
DSteck
CF Senior Member
DSteck's Avatar
Agreed, the wiring is trivial for them.
__________________
Old 11-25-2009, 11:03 AM   #7
ian@thetuningschool
Supporting Vendor
ian@thetuningschool's Avatar
The LC-1 is a great wideband if your only using it in your own car and the down side is it doesnt come with a screen to read AFR so you have to rely on Hp tuners reading it correctly. The NGK AFX is a great wideband and very accurate, plus you can move it from car to car.
Ian
ian@thetuningschool is offline   Reply With Quote
Old 11-25-2009, 11:25 AM   #8
DSteck
CF Senior Member
DSteck's Avatar
Quote:
Ian
The only downer to the NGK AFX (in my opinion) is that the display is programmed for 14.4 to be stoich instead of 14.7, but it doesn't matter much if you set up your scanning software to read the signal.
Old 12-06-2009, 12:53 PM   #9
seevi
CF Senior Member
seevi's Avatar
If your using 93 octane fuel with a 10% ethanol blend, 14.4 is pretty close.
seevi is offline   Reply With Quote
Old 12-08-2009, 12:12 PM   #10
Quickstrike Zo6
Junior Member
Quickstrike Zo6's Avatar
Send a message via AIM to Quickstrike Zo6
Quote:
Agreed...
Quickstrike Zo6 is offline   Reply With Quote
Old 12-08-2009, 03:09 PM   #11
DSteck
CF Senior Member
DSteck's Avatar
E10 is lower than that.
Old 12-09-2009, 08:57 AM   #12
seevi
CF Senior Member
seevi's Avatar
Quote:
Pardon my type, it's 14.1:1
Old 12-09-2009, 10:02 AM   #13
DSteck
CF Senior Member
DSteck's Avatar
I just deal with lambda now. It's easier.
Old 12-09-2009, 06:30 PM   #14
carlrx7
CF Senior Member
St. Jude Donor '08-'09
carlrx7's Avatar
Lambda is the key.!! 1.0 equals stioch for every fuel used!
carlrx7 is offline   Reply With Quote
Reload this Page Wideband lc1 vs ngk
Tags
afx, c5, corvette, e10, hp, lc1, ngk, tuners, wideband, wire, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
