Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-31-2009, 09:36 AM   #1
SteveL4446
CF Senior Member
SteveL4446's Avatar
Default Idle speed seems high
Had my new (2007) Z06 for about a week now. I'm still getting to know it, but the idle speed seems fast to me. When I start it cold it idles at about 1100. After it warms up (10-15 min) the idle drops to 900-1000. The car is stock with exception of a wild to mild switch. What should the idle be, and do I need to take it to the dealer to have it adjusted? Thanks!
SteveL4446 is offline   Reply With Quote
Old 10-31-2009, 09:50 AM   #2
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
Quote:
Stock idle is supposed to be 625 or so. Might have the dealer, or a tuner look at it. Is there a possibility it's been tuned?
edcmat-l1 is offline   Reply With Quote
Old 10-31-2009, 01:29 PM   #3
SteveL4446
CF Senior Member
SteveL4446's Avatar
Quote:
Thanks for the info. I suppose its possible that it was tuned, however everything looks and feels stock. I'll have to get it looked at.
Old 11-14-2009, 09:12 AM   #4
SteveL4446
CF Senior Member
SteveL4446's Avatar
The mechanic at the dealer said he called the tech center and they suggeted that the throttle body might be "carboned up" (?) He ran some cleaner through it and there was little if any change. Upon closer inspection, he found some kind of defect in the throttle body which he thought might be letting a small amount of air into the mixture. They intend to replace the throttle body (under warranty). We'll see.
Old 11-24-2009, 04:18 PM   #5
SteveL4446
CF Senior Member
SteveL4446's Avatar
They replaced the throttle body (under warranty).
Idles perfectly at 650-675. Much nicer.
Old 01-04-2010, 03:43 AM   #6
pakshana
Junior Member
Lotus Elise II: High Idle Speed and Cutting Out
By Nick Hibberd
Hibtech Auto-Electrical Diagnostics
The vehicle came in with a complaint of high idling and occasional cutting out. After further quizzing of the customer, the “cutting out” turned out to be stalling when pulling to a stop. I arrived at the vehicle on an unusually cold morning after it had stood overnight. The engine started normally except for an unusually high idle speed. It’s normal to get a slightly increased idle RPM on a cold engine because the idle stepper motor gets jacked open slightly to overcome fuel inefficiencies, but this was idling just under 3000 RPM.
The RPMs eventually dropped to a normal value (hovering around 1000) as the engine warmed up. Checking the system with a scan tool found no codes logged. Before doing a road test, all the preliminary work was carried out whilst in the workshop covering mechanical defects such as a sticking throttle cable, sticking throttle butterfly, inlet plenum air leaks, etc. Each area checked out OK. For good measure the throttle body and idle stepper motor were given a good clean. Then it was time for a road test.
antigua family resorts free cricket wallpapers
pakshana is offline   Reply With Quote
Reload this Page Idle speed seems high
Tags
1000, 1996, c6, corrvette, corvette, elise, fast, high, idle, idles, lotus, rpm, speed, speed94, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Why is my "Minimum Idle Speed Screw" covered up??? TIMSPEED C4 Tech/Performance 22 03-15-2004 10:45 AM
Idle speed problems / Vaccum routing question on big solid lifter motor TrueBlue ChevyDude Engine Mods 12 06-06-2002 11:35 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
