Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-20-2009, 12:20 PM   #1
m3to335
CF Senior Member
m3to335's Avatar
Send a message via AIM to m3to335
Default Hurrican CAI users, did you have to get a tune?
I was told the Hurricane didnt require a tune, but apparnetly that is not the case . After running it at the track for a few minutes I got an engine light. Its lean on bank 1 and 2.
Is this the norm? I know more air = the need for more fuel, but didnt know if it was outside the parameters of what it could adjust for.
If I have to get a tune, do you have any recommendations in that regard? Thanks!
m3to335 is offline   Reply With Quote
Old 10-20-2009, 11:48 PM   #2
06MonteSS
Supporting Vendor
06MonteSS's Avatar
Send a message via AIM to 06MonteSS Send a message via Yahoo to 06MonteSS
yes you need to adjust your tune... you need to get your fueling dialed in correctly in order to compensate for the additional amount of air flow that's being provided by the intake...
__________________
2006 Monte Carlo SS -- CAI, Poly mounts, STB's, FM Super 40's, Custom DiabLew Tune!
Email: 06MonteSS@diablewtune.com
06MonteSS is offline   Reply With Quote
Old 10-21-2009, 10:58 PM   #3
mi253
Junior Member
Yo, Put hurricane on + Nology wires and Billy Boat NPP exhaust, no codes and the noise from in the cockpit is impressive or not if you want. Mileage hasn't changed. I might however change how it bolts up to my mass air sensor, no rubber from unit to mass air flow sensor, understand that newer than 05' units have rubber gasket that go from Hurricane to Mass unit. Have friend in hose business think I' gona have him go to work and make secure seal. By the way recently had new built mustang next to me and after light at intersectioon and in middle of 2nd gear off light he backed offffff
mi253 is offline   Reply With Quote
Old 10-23-2009, 10:22 AM   #4
seevi
CF Senior Member
seevi's Avatar
For normal daily driving it shouldn't be a big problem unless you detect detonation. However, at WOT conditions you're going to be lean and will require an adjustment in your a/f ratio. So, ask yourself this question; $400-500 for a tune now, or, replacing some valves later? Good Luck!
seevi is offline   Reply With Quote
Reload this Page Hurrican CAI users, did you have to get a tune?
Tags
c6, cai, corvette, hurrican
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
