Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-19-2009, 08:45 PM   #1
Smkn 07
CF Senior Member
Smkn 07's Avatar
http://www.linkedin.com/pub/ernie-drake/32/bba/4a3
Default Do cooling fans turn off at highway speeds?
After a fair amount of forum searching (and posting this question in the tech section), I've found several statements that the C6 cooling fans turn off above either 30 mph or 35 mph. I've also found several statements to the contrary -- statements that say the fans run based upon temperature only, regardless of speed. I can't find clarification in the service manual either. Anyone know for sure if the fans turn off above a certain speed even if ect would otherwise cause them to run?
Thanks,
Ernie
Smkn 07 is offline   Reply With Quote
Old 10-20-2009, 09:31 PM   #2
chsndrms
Junior Member
chsndrms's Avatar
The fans in a normal situation will turn off above 35mph. In an overheat situation the fans will activate no matter what the speed.
Hope that helps!
chsndrms is offline   Reply With Quote
Old 10-21-2009, 12:48 AM   #3
Smkn 07
CF Senior Member
Smkn 07's Avatar
Quote:
Hope that helps!
Thanks for the reply. Let's say that my fan is set to be off at 196 degrees then turn on at 15% at 199 degrees. If my coolant temp is 205, for example, and the fan is running, will the fan turn off immediately if I exceed 35mph or will it run until the temp drops to below 199 regardless of my speed?
Old 10-21-2009, 06:41 AM   #4
REVAK
CF Senior Member
REVAK's Avatar
Quote:
Can't speak for all applications, however , on my 06,the fan is temperature and a/c controlled only. The fan follows the programmed temp. percentages regardless of speed.
REVAK is offline   Reply With Quote
Old 10-24-2009, 04:53 PM   #5
Smkn 07
CF Senior Member
Smkn 07's Avatar
Quote:
The service manual, because it makes no reference to speed being a determining parameter, would tend to support this.
Thanks.
Old 10-25-2009, 01:04 AM   #6
Mez
CF Senior Member
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Thanks.
In HP Tuners, the fan speeds can be set based on coolant temps as it should be. I think it makes total sense to control fans based coolant temp regardless of vehicle speed.
I've never seen any mention of vehicle speed and fans setting based on vehicle speeds in HP Tuners.
Mez is offline   Reply With Quote
Old 10-25-2009, 04:22 PM   #7
Skunkworks
CF Senior Member
The fan will be driven by tables related to coolent temps and AC if on not vehicle speed.
Mike
Skunkworks is offline   Reply With Quote
Old 10-25-2009, 07:29 PM   #8
seevi
CF Senior Member
seevi's Avatar
Fans are controlled by a engine coolant temperature table, and AC controls.
seevi is offline   Reply With Quote
Old 10-27-2009, 03:39 AM   #9
Shortimer
CF Senior Member
Support Corvetteforum!
Shortimer's Avatar
Good to know.
Shortimer is offline   Reply With Quote
Old 10-28-2009, 02:49 AM   #10
midgetracr
Junior Member
midgetracr's Avatar
Don't know about your engine but GM Supercharged V6's (L67 and L32) have a function in the VCM that turns fans off above a certain speed. Typically 35 MPH. The air flow thru the radiator at 35 MPH would be well above any air flow from the fan(s). Why waste the energy to run the fans when they would have no benefit anyway? If you have HP Tuners, look on the page for Fans in your VCM calibration and it will tell you for certain.
midgetracr is offline   Reply With Quote
Old 10-28-2009, 09:25 AM   #11
camarochevy1970
Junior Member
Quote:
That setting doesn't appear to exist, at least on the LS3 models
camarochevy1970 is offline   Reply With Quote
Old 10-29-2009, 02:15 AM   #12
4wheels
CF Senior Member
My '08 Z06 turns the fans off gradually over ~35 MPH, even if the ECU had them running previously below that speed. Data logging supports this. Although I haven't had it in an overtemp condition to see if there is a threshold temp that overrides this.
4wheels is offline   Reply With Quote
Old 10-29-2009, 06:38 AM   #13
camarochevy1970
Junior Member
Quote:
Yep, there sure is a temp correlation. I will post up an image of the settings when I get to work to show why it does that
Old 10-29-2009, 08:25 AM   #14
camarochevy1970
Junior Member
As promised, this picture should help explain how this system works
Reload this Page Do cooling fans turn off at highway speeds?
Tags
1999, 2003, c6, cooling, coolong, corvette, disable, fan, fans, forum, high, hp, mph, speed, speeds, tuners, turn
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
81 radiator - time to go ksems C3 Tech/Performance 20 05-13-2002 07:19 AM
installed 172-178 thermostat and throttle body coolant bypass today c5magred2 C5 Tech 22 08-24-2001 06:34 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
