Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-30-2009, 11:34 PM   #1
chad.orourke
CF Member
Default Just getting started here.....
So I had my car tuned by some kid with a laptop and I was marginally impressed with his work. He was however foolish enough to explain a little bit about how he was doing the tuning. Being a Systems Administrator by trade and a hobby mechanic that does most if not all of his own work I have determined I would rather do this myself than pay someone else to do it. I do however have some questions.
1. What is the complete list of purchases I need to make? I have seen tuner packages with the tuner suite and a wide band from tuningschool, but that by no means that is all I need. And yes I have a laptop.
2. Can I plug the wide band o2 into my rear o2 ports in my kooks headers and just leave them there for the life of the car? If so how do you wire the sensor in to the cabin?
3. I would like to have a gauge pod on the A-pillar at some point so if there is a package that will somewhat match a quality boost gauge that would be great as well. If I was to run gauges then which ones should I run with?
All help is appreciated and before you mention it yes I plan to use the home school method with the tuning school.
Thanks again
Chad
chad.orourke is offline   Reply With Quote
Old 10-01-2009, 08:25 AM   #2
Mez
CF Senior Member
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Thanks again
Chad
Along with tuning and scanning software package, such as HP Tuners, I highly recommend a WB02 kit. Of course, you already know that. There is a steep learning curve especially how to use the software. Its not that intuitive. I am still learning some features of the scanning software.
In my case, when I was calibrating the VE and MAF tables, I simply put the PCM in open loop, set the PCM commanded AFR to 13:1 and ran around recording the AFR % error and changing the tables until the commanded AFR and actual were withing 1-2% at all RPM and loads. Then reinstalled the NB and put the PCM back in Close Loop. If you go to HP Tuners website, you can download instructions how to do this.
Its a good idea to have a separate O2 bung welded into a header collector just for the WB02 because for the PCM to run in closed loop it needs to receive a signal from the NBO2 sensors. Because the NB and WB output not the same voltage, you simply can not substitute the WB for the NB. My PLX WB02s connects to a dongle which has an output at the NB voltage so it is possible but I would have to modify the original NB wiring harness or connector which I was not willing to fool with.
If you want to install a permanent WB gauge, then just add the bung to the header. The passengers side seems to have enough room.
I learned by reading the HP Tuners fourm. I had a mentor in town who I could call and ask questions. I also bought up Greg Banish's book "Engine Management Advanced Tuning" at Barnes & Noble. You can order it on-line, too. I consider this a must have book as it explains theory and the process of tuning.
Good luck.
Mez is offline   Reply With Quote
Old 10-02-2009, 04:23 PM   #3
ian@thetuningschool
Supporting Vendor
ian@thetuningschool's Avatar
Thanks again
Chad
Hey chad,
Give me a call if you would like to know more on what The Tuning School offers, ill be glad to take care off you. 727 264 8875
Ian
ian@thetuningschool is offline   Reply With Quote
Reload this Page Just getting started here.....
Tags
car, texas, tuningschools
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1962 Corvette (Trouble getting started) Dorsil C1 & C2 Corvettes 16 04-25-2005 12:44 PM
Another new guy getting started! drdoug75 Audio/Electronics 9 11-29-2004 05:37 PM
Shopping for a C3…just getting started…questions snampro C3 Tech/Performance 12 04-03-2004 12:19 AM
just getting started...and would love some help marylandz C4 ZR-1 Discussion 17 12-08-2002 05:19 PM
HAMBO-MOBILE is getting started? TCC5 Great Lakes 20 01-29-2002 01:13 PM
Getting Started - Restoration Project Mordi Factory Correct Resto 27 12-07-2001 04:43 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
