Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-25-2009, 07:56 PM   #1
op z
CF Senior Member
op z's Avatar
Default Predator Problems...
Bought a used 7194 predator from a forum. When I plug the 7194 in the car (2008 LS3) and put the car in the accessory mode the predator keeps asking me to verify that the key is in the start position. When I press continue it asks the same question a couple more times and then says to unplug the unit and start over. I did this three times with no success.
For a while the Predator was communicating with the car after selecting higher baud rate and selecting manual transmission. When I select performance tune, it only asked if I want to modify the stock tune or back up the stock tune. There were no Predator tunes available.
Someone on the Predtor forum recommended updfating the firmware to the latest version (9.9). Now I can't get it to recognize the tool and now I get a service fuel system message with the gauge showing empty.
Any thoughts?
op z is offline   Reply With Quote
Old 09-25-2009, 08:24 PM   #2
carmos
CF Senior Member
carmos's Avatar
hi ,if you are getting service fuel system error .it did write somthing to your pcm...are u sure u did not back up the the original tune...also maybe it was still locked to the car of the person that sold it to u,and wrote somthing to urs anyway...i would get on the phone diablo asap..they seem preety helpful when u can get a hold of them...
carmos is offline   Reply With Quote
Old 09-25-2009, 09:26 PM   #3
op z
CF Senior Member
op z's Avatar
The fuel system error corrected itself by disconnecting the battery for a few minutes. Still cannot communicate wityh the car. What should the baud rate be set to? Does it matter? Does it matter what the trans is set to?
Old 09-25-2009, 09:37 PM   #4
carmos
CF Senior Member
carmos's Avatar
Quote:
the only time i have had to change the buad rate is when the predator is talking to a laptop to download info from or to it...i have an auto trans so thats what it needs to be.if u have a manual then set it to that...i would really recommend you do update the predator to the latest firmware...things will go much soomther..
Old 09-25-2009, 09:39 PM   #5
op z
CF Senior Member
op z's Avatar
I did that and it did't help. Did you by yours new or used? LS3?
Old 09-25-2009, 09:46 PM   #6
carmos
CF Senior Member
carmos's Avatar
i bought it new from maryland speed...then updated it to work with the my ls3...make sure you take out the fuse for on star and radio and anything drawing power is turned off...i had that problem when i first did it..
Old 09-25-2009, 09:54 PM   #7
op z
CF Senior Member
op z's Avatar
My onstar is ot active,but that's the last thing I haven't tried. I'll dive it a shot in the morning. All you do is put the car in the accessory mode? Nothing elese needs to be done?
Old 09-25-2009, 09:56 PM   #8
carmos
CF Senior Member
carmos's Avatar
correct.hope it works out...
Old 09-26-2009, 03:26 AM   #9
da vette guy
CF Senior Member
da vette guy's Avatar
Patrick,i sent a pm with my phone number if you are still having problems.i think i held the accessory button for 10 seconds to put car in the on(run) position to program my car.also you might try downloading the new update again if the above doesn't do it(in case some file on the programmer has somehow become corrupted). i think 06MonteSS is the resident expert on the predator,i sent him a pm to see if he had any ideas.richard
da vette guy is offline   Reply With Quote
Old 09-26-2009, 09:53 AM   #10
op z
CF Senior Member
op z's Avatar
Surprisingly enough, I put the car in the run posit ionby not pushing in the clutch while I pushed the start button and it downloaded the tune first time. All the guidance I've read to date says to put the car in the accessory mode. Must have tried that 20 to 30 times with no luck.
Reload this Page Predator Problems...
Tags
06, configuration, corvette, diablosport, predator, problems
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
DiabloSport Predator Pre-Order Special Pricing Extended! RWTD C5 Tech 591 09-20-2004 06:15 PM
Hypertech or Predator badblackc5 C5 Scan & Tune 28 08-25-2004 02:37 PM
0-60 performance for '99 A4 Vert with 3.42 diff and Predator tune berryj C5 Scan & Tune 37 06-16-2004 12:00 AM
whats up with LG header problems?? FRC sexi blk C5 Tech 37 03-24-2004 01:53 AM
Impression from new Predator Owner brianw21 C5 Scan & Tune 16 09-03-2003 09:37 PM
Diablo Predator Piece of S((** WhiteC5Vette C5 Tech 37 08-26-2003 03:45 AM
Predator Downloads PalmettoVetteMan C5 Scan & Tune 14 01-11-2003 12:01 AM
I'm sending my Predator back for... Mike Mercury C5 Scan & Tune 11 11-27-2002 11:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
