Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-21-2009, 06:30 PM   #1
fperra
CF Senior Member
Support Corvetteforum!
fperra's Avatar
Default EFI Live tune question on LS7
When the water temps on my forged LS7 get above about 215*F, it takes about 5 seconds or more of cranking before it finally stumbles into a rough idle. A few pumps of the gas pedal and the idle settles down. Can anyone point me to which table in EFIlive that will address this problem.
fperra is offline   Reply With Quote
Old 09-27-2009, 09:38 AM   #2
ringram
Junior Member
You could approach this from a couple of angles.
First 215*F is reasonably hot, quite a few guys rescale the fans with the fan patch to come on sooner. You can get it to hold engine temps around 195*F that might fix your issue and also give a little more power through cooler under bonnet temps etc.
Otherwise take a look at cranking idle air as well as cranking commanded fuel (B0138, B1832) for example.
ringram is offline   Reply With Quote
Old 09-27-2009, 10:32 AM   #3
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
There are a bunch of spark tables that interact and getting it to start up nicely when warm is an art. If you'd like to email me your tune I can make some changes and send it back. That would be easier than trying to explain over the internet.
edcmat-l1@msn.com
edcmat-l1 is offline   Reply With Quote
Old 09-28-2009, 02:27 AM   #4
HNK
CF Senior Member
Quote:
edcmat-l1@msn.com
As a rule of thumb, what needs to be done? less cranking air/timing or more?
HNK is offline   Reply With Quote
Old 09-28-2009, 11:59 AM   #5
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
Quote:
It has way more to do with the timing tables than it does any of the airflow tables. Matter of fact, the closer you get to optimum on the timing tables, the less airflow you'll need both in the idle table, and the cranking airflow table, which helps a bunch on the flare up when starting up warm.
Old 09-30-2009, 11:48 AM   #6
fperra
CF Senior Member
fperra's Avatar
edcmat-l1@msn.com
email sent.
Old 10-08-2009, 06:15 PM   #7
ringram
Junior Member
Thanks Ed.
I take it that doesnt always apply, for example with certain cams?
But always good to sponge up more info.
Reload this Page EFI Live tune question on LS7
Tags
efi, efilive, fan, live, ls7, patch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
