Quote:
Originally Posted by wcrmltd
This helps. can you tell me what is keeping the power or torq from coming on at lower RPM. something in the system is keeping torq down until either the clutch in the auto trans are full engaged or it feels this way. up in the rpm range it really seems to turn things loose. what is keeping it down in the program if not TM.
Many things can cause this. TM is one, another is the fact that with the A6 the car shifts way to damn early. To keep gas mileage up, our cars run at around 1300 rpm when cruising. This is just too low when you jump on it, causing some hesitation.
I had my shift points changed when I had my car tuned. My car now shifts at about 2000 rpm in all gears. The car now cruises at around 1500-1800 rpm. When I jump on it, the car is more in the power band of the rpm range, giving me less of a hesitation, and instant power.
Have both your car and tranny tuned and it will feel like a different car.
