Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-07-2009, 01:31 PM   #1
dsp300c
CF Senior Member
dsp300c's Avatar
Send a message via AIM to dsp300c
Default Where to weld the bung?
I am about to buy an NGK or FJO wideband but not sure which one to go with yet. Still researching. Once I get my wideband where is the best place to weld the bung? Here is the link to LG headers and midpipe I have. I see the O2 bung at the collector. Do I put wideband bung before or after the O2? Pass or driver side? Any help would be appreciated.
http://www.lgmotorsports.com/catalog...oducts_id=1515
dsp300c is online now   Reply With Quote
Old 09-07-2009, 02:37 PM   #2
ShinodaVette
CF Senior Member
ShinodaVette's Avatar
Driver's side is usually recommended but you can do either side. My Kooks x-pipe came with the WB O2 bung pre-welded in but they put it in the passenger side before the cats but after the front O2s since they are actually in the headers instead of the x-pipe. Seems to work fine in this location for my NGK AFX wideband.
__________________
Our Toys:
ShinodaVette is offline   Reply With Quote
Old 09-07-2009, 03:05 PM   #3
09C6Coupe
CF Senior Member
09C6Coupe's Avatar
Welding the bung is hazardous to your health.
Drivers side 6" before the cats 2 o'clock position to preven it from retaining water.
09C6Coupe is offline   Reply With Quote
Old 09-07-2009, 04:36 PM   #4
dsp300c
CF Senior Member
dsp300c's Avatar
i don't have cats so how far after the o2 bung on the driver side should i put it? in the pic it looks i can do it between the o2 and clamp or right after the clamp
Old 09-07-2009, 05:34 PM   #5
09C6Coupe
CF Senior Member
09C6Coupe's Avatar
I would do it just before the clamps and make sure it has a clean stream of exhaust hitting it that isn't interupted by the o2 sensor. Sorry, I didn't notice that there were no cats in the pic.
Reload this Page Where to weld the bung?
Tags
afx, bung, c5, corvette, o2, prewelded, side, weld, wideband
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Where to weld wideband O2 bung? Tony @ MPH C5 Tech 13 10-22-2004 01:39 PM
Aftermarket Radiator and Electric Fan Installation How-To HunterRose C3 Tech/Performance 10 10-26-2003 11:05 AM
I just love UPS! Hooker 2151's LD85 C4 Tech/Performance 40 02-06-2003 09:52 AM
Motors in and the tpi is trial fitted with pictures. PatsLs1vette C3 Tech/Performance 17 08-16-2002 01:04 PM
Wideband O2's to install instead of stock front O2's. Where to get? vette.se C5 Tech 13 07-15-2002 03:18 PM
A vacuum leak is making my car faster. Whats the deal? JoeMacgruder C3 Tech/Performance 13 06-17-2002 01:09 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
