Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-26-2009, 03:03 PM   #1
stanger383
CF Senior Member
St. Jude Donor '09
stanger383's Avatar
Default 05 a4 timing
hi just put hptuners on my 05 a4 vert. the car ran 12.93 showroom stock and I just put LG longtubes 3 inch x and high flow cats and complete z06 mufflers including the 3 inch over axle pipes that belong on them as well as a vararam. when i logged some runs it gets 1.4 to 1.6 degrees KR the first second or two of first gear and then none after that. it shows that Im only getting 19 to 20 degrees total timing through all gears on my run log. Is that normal timing with no KR? how much can you typically get away with and be beneficial with 93 octane only? Any input would help. I feel as though the car would run 12.30s right now. It almost seems like the KR comes in at opening of the throttle. I did remove some of the TM (down to 15 percent in 1st and 2nd) Thanks in advance
stanger383 is offline   Reply With Quote
Old 08-27-2009, 12:11 AM   #2
Mez
CF Senior Member
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Most people add a few more degrees of advance in the upper RPM at WOT.
Is it burst knock or KR?
Mez is offline   Reply With Quote
Old 08-27-2009, 10:45 AM   #3
stanger383
CF Senior Member
St. Jude Donor '09
stanger383's Avatar
is burst knock exhaust rattle or is it something else? which timing table do I bump up to do it rpm related? it showed as KR on the log.thanks
Reload this Page 05 a4 timing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Quality Issue? JetC6 C6 Corvette General Discussion 39 07-20-2005 11:42 PM
2004 Torch Red Convertible - Supercharged - Stunning! 2k1 Vette C5 Corvettes for Sale 9 05-24-2005 10:58 PM
Does changing the rear gear ratio change the RWHP #? mowrey96 C5 Tech 101 01-27-2004 11:17 PM
Any thoughts on my next cam? Phil97SVT C5 Tech 10 10-30-2002 10:14 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
