C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Sponsored by AMS Performance
08-25-2009, 12:18 AM
CF Senior Member
high gear at low RPM giving a larger amount of throttle
curious if any of you have observed this. Being in a high gear at low RPM giving a larger amount of throttle causing knock. Obviously not a smart thing to do but I am just curious.
08-25-2009, 12:22 AM
CF Senior Member
I'm guessing it's just lugging the engine causing the knock
08-25-2009, 09:06 PM
CF Senior Member
St. Jude Donor '08-'09-'10
Quote:
Originally Posted by
da vette guy
08-25-2009, 09:14 PM
CF Senior Member
depends what your timing map looks like.. @ high load and only 800-1k rpms, my timing map is showing -18 degrees,, what is your showing?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
