Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-20-2009, 11:39 PM   #1
pmj341
CF Senior Member
St. Jude Donor '08-'09-'10
Support Corvetteforum!
pmj341's Avatar
Send a message via AIM to pmj341
Default Kr- timing only 15 degrees
Guy's I'm getting 3-6 degrees of retard from 4800 to 6000
108-112 g/sec, timing is already 15-17 degrees
Any ideas???
most engines run 23-27 degrees around the same RPM and g/sec, WHY??
thanks for your help!!
pmj341 is offline   Reply With Quote
Old 08-21-2009, 06:16 AM   #2
carlrx7
CF Senior Member
carlrx7's Avatar
check your exhaust and make sure you have 1/4 inch of clearance from the body, any contact will transmit vibrations back to the engine and it will pull timing (False KNOCK),, also make sure your motor mounts aren't worn out, causing the exhaust to move excessively.
if your running N/A thats deff low timing, pull another 6-7 degrees and add another .5 point of fuel,, if its still knocking then its 99% false. try and adjusting the knock sensor values.
Or instead you can put some 110 octane in it and see if it goes away.
p.s. i just recently purchased HPTuners Pro and in the process of reading all of their stickies on the forum. ive never touched the program and am just regurgitating info i read there.
-Carl
carlrx7 is offline   Reply With Quote
Old 08-21-2009, 09:47 AM   #3
pmj341
CF Senior Member
pmj341's Avatar
Carl
thanks, I also think it is exhaust related, but I seem to have plenty of clearance.
I'll put some Octane booster and recheck!!
Old 08-21-2009, 05:55 PM   #4
Mez
CF Senior Member
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Did you check your A/F ratio at WOT with a WB02 sensor installed?
If it was running lean, it will knock.
Mez is offline   Reply With Quote
Old 08-22-2009, 09:44 AM   #5
pmj341
CF Senior Member
pmj341's Avatar
I did, I have a permanent WB and my AFR are 12.6@WOT, LTFT's are great.
I have gradually backed up my timing from 23 to 17 degrees and Kr still
shows up from 3 gear and up.
put my car on the 4 post lift and cranked it up, put it in gear and
held the rpm at 1400, I looked for anything close that could contact
nothing found, all my scans show something from 4400 to 6000 and
no Kr from 6000 to 7000, and timing above 6200 goes up to 26-28.
Even though I did not see any contact on the exh I still believe that
something is making contact with the frame or trans.
thanks for your replies!!!
Old 08-22-2009, 09:28 PM   #6
Mez
CF Senior Member
Is there any change if you change your PE table to, say, 11.5:1 to determine if it is fuel related. I noticed if the PE was too lean, I would a few degrees of KR at peak torque in the 4800-5200 rpm. If there is no change, that would seem to indicate it may be burst knock or something banging on the exhaust system.
Also, you may want to check the plugs and make sure all are gapped at .040 and there are no vacuum leaks.
Old 08-23-2009, 10:02 PM   #7
REVAK
CF Senior Member
REVAK's Avatar
Is your gas E-10, [10% ethanol] ? If so you need to adj your WOT af ratios by 4% [ 3.9 to be exact], richer. I went through this same problem, in my case it was a lean issue. With a 100% gasoline blend, 12.6 afr on your gauge is 12.6 . With E-10 , 12.6 on your gauge runs like 13.1, that is to the engine , it is 13.1. With E-10 , if you want your engine to see 12.6, you must adj. your WOT afr to read 12.1 on your gauge. If you have access to non ethanol gas , try it . if that fixes your problem then you'll know.
REVAK is offline   Reply With Quote
Old 08-23-2009, 10:19 PM   #8
pmj341
CF Senior Member
pmj341's Avatar
Quote:
I'll give it a try!!
thanks
Old 08-23-2009, 10:56 PM   #9
Mez
CF Senior Member
What year is your car? My 2005 PCM does not measure the % ethanol in the fuel when calculating AFR but the newer ones do. I forget which year this feature was added, but if you do some research, yours may already take that into account.
Old 08-24-2009, 10:01 AM   #10
REVAK
CF Senior Member
REVAK's Avatar
Mine is an 06, I don't think my car has that feature. When I set my scanner to read % eth. , there is no data value. We've had the crap 10% eth. gas for nearly 2 years now here in eastern Pa. Thanks for the info about eth. compensating feature, I did not know they addressed that. It does tell us though, it is a legitimate problem , or they would not have bothered with it.
Old 08-26-2009, 08:42 PM   #11
pmj341
CF Senior Member
pmj341's Avatar
guys, I added 110 octane fuel 5gals to 1/4 tank of 93 and it made no diff on my
Kr.
Christopher suggested to unplug the pass side Knock sensor and do a scan and see if anything diff happens, follow up with unplugging the drivers side and repeat scan.
I will try that sat!!
We agree that something is rubbing is causing the Kr (mechanical)??
Old 08-26-2009, 11:36 PM   #12
Mez
CF Senior Member
Kr.
Is it burst knock or knock retard?
Old 08-27-2009, 08:30 AM   #13
pmj341
CF Senior Member
pmj341's Avatar
It did not change from 25* of timing to 15* so I figure since I tried the Octane, that something in the engine or on the exhaust is hitting.
Old 08-27-2009, 08:43 AM   #14
Mez
CF Senior Member
Burst Knock Retard is predicted knock. Real Knock Retard happens when the knock sensors pick up knock.
Old 08-27-2009, 12:31 PM   #15
pmj341
CF Senior Member
pmj341's Avatar
I will unhook the Knock sensors one at a time to determine if it's one or the other
Old 09-05-2009, 02:44 PM   #16
pmj341
CF Senior Member
pmj341's Avatar
Well, I believe I found the problem.
I removed the plug from the RH Knock sensor and did a scan from 1st thru 4th, no knock retard at all.
Christopher Martin had the same problem, he told me to try it, and it worked!!
the problem was the header making contact with the frame, I had clearance issues after installing the headers, so I removed some material and got 1/4" clearance, I was sure that was enough, but under full throttle the engine moves enough to hit, 1/4" is not Enough you need more.
I will figure a way to get more room.
Old 09-05-2009, 03:58 PM   #17
Mez
CF Senior Member
I believe I have a similar problem.
Old 09-05-2009, 10:41 PM   #18
Joe_G
St. Jude Donor '08
Joe_G's Avatar
I had to use a BFH (actually a BF Channel Lock first) on my passenger floorpan seam to fit my AR headers. Sounds like you need to do the same!
Big day next Sat open track all day am Challenge that night, hope to see you there bud.
__________________
2005 Vert Z51 MZ6
Horsepower Sales 954-984-8040
4:10's, FAST 92, A/R Headers w/cats, G5x3, .040 gaskets AFR 205 heads ORIG CLUTCH
472rwhp/414rwtq
Best pre-cam:1/4-1.730, 11.810@118.76
Best w-cam, pre-FAST 1/4-1.666, 11.540@121.39
Best w-cam & FAST 1/4-1.519, 10.995@126.67 DA-793
Best w-cam & AFR heads 1/4-1.445, 10.815@128.07 DA-581 1/8-1.445, 6.920@99.15 DA-581
Top speed 185 (so far...) 0-60 mph 2.59 sec (track)
Joe_G is online now   Reply With Quote
Old 09-06-2009, 11:39 AM   #19
pmj341
CF Senior Member
pmj341's Avatar
Hey, Joe!!
I wonder why most AR headers have this problem??
I've been wanting to go, I would have to go early to avoid the Rain!!
now I will be able to bump my timing up to were it should be, maybe it will help my MPH.
How early are you going??
Old 09-06-2009, 12:23 PM   #20
Joe_G
St. Jude Donor '08
Joe_G's Avatar
Hey, Joe!!
Sounds like their jig needs to be adjusted a bit. I had one of the first sets so I figured it was a birthing pain. Guess not!
You will get your 10 second slip for sure next Sat.
I can't get there that early due to family commitments. Evenings are much better for me. Plus it's so darn hot in the sun all day. Gates open at 8 and track is hot at 10 am.
Reload this Page Kr- timing only 15 degrees
Tags
110, c6, corvette, false, knock, kr, octane, pulling, taking, timing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
VCM Suite 1.7.0 Available Now!! Ken@HPTuners C5 Scan & Tune 15 07-23-2011 11:50 AM
this is for everyone who thinks an efficeint homemade tt can't be done! SR71 C5 Forced Induction/Nitrous 23 04-12-2005 08:43 PM
All roads lead to MAF~~ Dat Pesky MAF BlueDragon C5 Scan & Tune 9 12-24-2004 12:06 AM
04 Predator install N2DEEP C5 Scan & Tune 38 10-31-2004 04:59 PM
Found the key to part throttle Performance tuning... chuckster C5 Tech 56 08-16-2004 09:06 PM
Does anyone have Andy's Head/Cam special? MagRed01Atty C5 Tech 17 05-19-2004 09:01 PM
ls1 Edit and timing ?? Rays Vet C5 Scan & Tune 16 02-04-2004 12:24 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
