Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-17-2009, 08:48 PM   #1
fperra
CF Senior Member
Support Corvetteforum!
fperra's Avatar
Default Cam surging question
I have a RR Stalker cam in my supercharged C6 ZO6 and haven't been able to tune out the low rpm surging in 1st, 2nd, 3rd and 4th gear in the rpm range of 1500 to about 2200. I've increased the timing in that area and increased the minimum idle airflow in that range which has improved the situation, but I haven't eliminated it. Any suggestions?
fperra is offline   Reply With Quote
Old 08-17-2009, 09:15 PM   #2
Amric
CF Senior Member
What are your cam specs?
How much did you increase your timing below 2000 RPM in your main spark table?
How much did you increase your timing below 2000 RPM in your idle spark table?
How much did you increase your timing below 2000 RPM in your coastdown spark table?
What percentage above stock is your minimum airflow?
Everyone's setup is different, but my LS3 with a 242 duration 115 LSA going through 1 7/8 headers and no cats needed about 5 degrees more timing in those cells and below (on average) due to the EGR effect of the cam overlap. Idle minimum airflow needed to be increased almost 40%.
Those changes, and getting the VE and MAF dialed in, got the low end torque and MPG back to right were they were with the stock cam, and removed the surging.
I can not see the supercharger being much of a factor at those lower RPM, but I have never tuned one, so other will know more than I do.
If the cam was similar to mine, combined with the larger stock cam, and larger displacement, a good starting point may be 3 degrees across the whole range in all 3 tables, and 20-30% more idle minimum airflow.
Amric is offline   Reply With Quote
Old 08-18-2009, 05:16 AM   #3
MrDrezzUp
CF Senior Member
MrDrezzUp's Avatar
For my car, reducing the timing was the key in eliminating the bucking/surging.
5_Liter_Eater has a great writeup on how to dial in the minimum airflow table.
MrDrezzUp is offline   Reply With Quote
Old 08-18-2009, 06:52 AM   #4
thegreenman
CF Senior Member
thegreenman's Avatar
Location: Yorktown VA..............., 570 RWHP and 545 TQ
Are you sure it is your cam and not your MAF?
After I installed my SC and had it tuned I decided to cut out my radiator shroud for some cooler air and now get the same surge in the RPM range you mention. The LS3 is known to have problems with the MAF with CAI's and I am assuming the Z06 has the same MAF.
thegreenman is offline   Reply With Quote
Old 08-18-2009, 11:06 AM   #5
fperra
CF Senior Member
fperra's Avatar
Can you point me to where that writeup is?
Old 08-18-2009, 11:10 AM   #6
MrDrezzUp
CF Senior Member
MrDrezzUp's Avatar
Quote:
PM sent!
Old 08-18-2009, 01:03 PM   #7
4evervette
CF Senior Member
4evervette's Avatar
try to search the hptuners forum... there is alot of info about this ..i just order the same cam due it size ( smallish) so i dont get into those problmes ...
and i have to agree ..i have read that both adding timing or subtracting it is one way of solving the problme .....
4evervette is offline   Reply With Quote
Old 08-18-2009, 08:56 PM   #8
abicarsy
Junior Member
I think it is the MAF not Cam.
Chevrolet Corvette 2008 Car Parts Information
abicarsy is offline   Reply With Quote
Old 09-01-2009, 06:20 PM   #9
MasportDan
Supporting Vendor
It's a combination of many factors, but what you're trying to do when you tune for this is reduce the effects of intake reversion. By reducing timing, you reduce engine torque and that helps somewhat. So does driving in a higher gear (taller ratio). When you increase timing advance, generally the engine will produce more torque and have slightly higher manifold vacuum for a given throttle opening at that engine speed. The effects of intake reversion due to cam timing are generally compounded by the springs in the clutch disc on manuals, and reduced or damped somewhat in auto trans cars by a higher stall converter. Unfortunatley there's no easy answer...you have to tune for the components in your car. Trans type, rear axle ratio, MAF size, head port area and length all affect reversion, so each car is a little different. Tune for maximum refinement for how you drive the car and what parts you've put in it.
MasportDan is offline   Reply With Quote
Old 09-01-2009, 09:56 PM   #10
MrDrezzUp
CF Senior Member
MrDrezzUp's Avatar
Quote:
Would the amount of intake reversion be directly related to the amount of cam overlap?
Old 09-01-2009, 10:43 PM   #11
MasportDan
Supporting Vendor
Not directly, but it does influence it. The tighter the LSA, the worse the reversion becomes. If you have a wider lobe separation, you'll have higher intake vacuum (lower kpa on your data log) and thus a more stable idle. The intake duration and timing greatly affects reversion, for if you close the intake valve later (higher up on the compression stroke), reversion increases as the piston pushes some of the intake air back up through the intake manifold. Cams are a compromise for the performance you wish to achieve from the engine, which is why infinitely-variable valve timing and lift is so desirable. You can have your cake and eat it too.
Reload this Page Cam surging question
Tags
1993, cam, car, corvette, reduce, reducing, reversion, surging
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
'66 327/350 - Jerking/Surging Problem docwisdom C1 & C2 Corvettes 11 10-03-2004 09:18 PM
Z06 Cam Specs vs 99 C5 Cam Specs... question>> SilverC5Vert C5 Tech 30 03-23-2004 02:06 PM
WOT popping at 4500 rpm question Surfer69 C3 Tech/Performance 15 01-24-2004 10:29 AM
CAM Discussion....I need some opinions for my LT4.... Shriker C4 Tech/Performance 47 02-01-2003 02:17 AM
Why is my idle surging? kwik8racr C5 Tech 11 09-18-2002 01:22 PM
Big Cam owners question? Phil97SVT C5 Tech 16 07-01-2002 04:43 PM
Another carb question: Why is my idle all over the place? Shrike C3 Tech/Performance 13 04-10-2002 06:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
