Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-02-2009, 10:06 PM   #1
Spying Beast
CF Senior Member
Spying Beast's Avatar
Default DOH! Hp Tuners issues
So I finally manned up and decided to plug in my lap top with HP tuners to the car.
All that happened is that a window popped up saying that the connection failed, the car died, and the column lock thing popped up. I restarted the car, tried to read the tune again, and the same thing happened.....
What am I doing wrong?
Spying Beast is offline   Reply With Quote
Old 08-02-2009, 10:12 PM   #2
Motorhead-47
CF Senior Member
Support Corvetteforum!
Have you posted over on the HP Tuners forum? That would be my first stop. I can't answer the "car died" part but I do know if you try and run the data log feature while the DTC read window is open HP Tuners will drop the connection. Are you running both the Scanner and the Editor at the same time by chance?
Motorhead-47 is offline   Reply With Quote
Old 08-02-2009, 11:13 PM   #3
Spying Beast
CF Senior Member
Quote:
Nope, just opened the editor, and clicked on read entire, or something like that.
Is there a sequence to go by, like start the car, then plug in the computer, then start the lap top, etc. that is not included in the instruction manual that doesn't come with HP tuners?
Old 08-02-2009, 11:42 PM   #4
Amric
CF Senior Member
Do not read entire with the engine running. Put it in Auxilary mode, and they try to read the stock tune.
Amric is offline   Reply With Quote
Old 08-03-2009, 06:29 AM   #5
Motorhead-47
CF Senior Member
As mentioned above to either read or write the file the car must not be running!
Old 08-03-2009, 10:12 AM   #6
WhiteLightning_
CF Senior Member
Quote:
the car should NOT be running when you are doing anything with HP tuners.. like amric said.. put it in aux and you should be good to go.
WhiteLightning_ is online now   Reply With Quote
Old 08-03-2009, 02:03 PM   #7
Motorhead-47
CF Senior Member
Quote:
Unless you are running the "Scanner" application in the HP Tuners suite...pretty sure you want the car running for that one.
Old 08-03-2009, 02:44 PM   #8
DarthStimpy
CF Senior Member
DarthStimpy's Avatar
Send a message via AIM to DarthStimpy Send a message via Yahoo to DarthStimpy
hold the bottom of the start button down for 10 seconds until your greeting comes up. (this is NOT accessory mode, this is about 5 seconds PAST accessory mode)
After you do this you can do a read or flash.
DarthStimpy is offline   Reply With Quote
Old 08-03-2009, 02:59 PM   #9
pmj341
CF Senior Member
St. Jude Donor '08-'09-'10
pmj341's Avatar
Send a message via AIM to pmj341
it is not very smart to try to do anything on these cars without knowing what to do!!!
1 plug cable to laptop and car
2 open Editor
3 starter button to acc mode
4 laptop read entire and SAVE, name it!!
when done stater to OFF
look over Editor to check what you might want to change, provided you know what needs to be changed.
for Scan
1 cable hooked to laptop
2 Acc on
3 Scan mode, open gauges and start scanning,
4 start car double click space bar, it will start scanning.
Good luck!!!
pmj341 is offline   Reply With Quote
Old 08-04-2009, 12:07 AM   #10
da vette guy
CF Senior Member
da vette guy's Avatar
2 open Editor
for Scan
2 Acc on
Good luck!!!
Great info....
da vette guy is offline   Reply With Quote
Old 08-04-2009, 01:08 AM   #11
Spying Beast
CF Senior Member
Perfect fellas, thanks. Splains it all....
Old 08-04-2009, 02:23 AM   #12
WhiteLightning_
CF Senior Member
yeah. but since he mentioned he was trying to download the stock tune you can assume he wasnt using the scanner
Old 08-04-2009, 11:04 AM   #13
drmustang
CF Senior Member
How long do you hold down the bottom of the button to get accesory mode where HP can connect? I seem to allways have a terrible time connecting.
drmustang is offline   Reply With Quote
Old 08-04-2009, 11:07 AM   #14
DarthStimpy
CF Senior Member
Quote:
um.. 10 seconds...
Old 08-04-2009, 11:46 AM   #15
RLSebring
Supporting Vendor
RLSebring's Avatar
Robert Sebring Robert Sebring
Being in accessory mode isn't going to do it You need to be in run but not crank/start mode which is the "hold the bottom of the button down for the 10 seconds or so" procedure.
__________________
In the Swamp where the only thing that
come's out alive is the Gators.
A New Year to tell the tale. The tale is told for this year. What's it gonna be next year...
GO GATORS!!!
08 Vert
"Tail of the Dragon" 9/14/2009
RLSebring is online now   Reply With Quote
Old 08-04-2009, 10:06 PM   #16
Amric
CF Senior Member
Strange, because I run a new tune every day, and the 100+ times I have done it with just Acc mode. No 10 sec hold.
Old 08-05-2009, 01:04 AM   #17
Spying Beast
CF Senior Member
You have just entered the twilight zone..... Do do do do, do do do do....
Old 08-05-2009, 08:32 AM   #18
pmj341
CF Senior Member
pmj341's Avatar
Quote:
I have never held the button down, I put it in Acc mode and copy or download, no problems at all!!
Old 08-05-2009, 09:59 AM   #19
DarthStimpy
CF Senior Member
you are aware that the ECU has a limited number of writes?
Old 08-05-2009, 03:20 PM   #20
foff667
Premium Supporting Vendor
Send a message via AIM to foff667
Thats news to me.
foff667 is online now   Reply With Quote
Reload this Page DOH! Hp Tuners issues
Tags
c5, car, corvette, download, file, forum, hp, issues, pensacola, problems, read, running, scanner, tune, tuner, tuners
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
