Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-31-2009, 07:34 PM   #1
capicciuti
CF Senior Member
capicciuti's Avatar
Default Can GM spot a Tune via On-Star
I am a week away from buying a hand held tuner. I was reading the instructions and they warn to remove on-star fuse while doing tune so no on-star signal would mess up the tune. This got me to wondering if with all the diognostics that on-star does would GM be able to spot a tune. If so I sure don't mind keeping the on-star fuse out. Thanks for any insight.
capicciuti is offline   Reply With Quote
Old 07-31-2009, 07:54 PM   #2
bluev2srt
CF Member
Send a message via AIM to bluev2srt
If I remember correctly it is so onstar does not power up and mess up the tune. Aparently it can work when the key is off and do its thing. I don't believe there can be any tune info sent through the system.
bluev2srt is offline   Reply With Quote
Old 07-31-2009, 11:39 PM   #3
da vette guy
CF Senior Member
da vette guy's Avatar
i wondered about that too and never activated my onstar
da vette guy is offline   Reply With Quote
Old 08-01-2009, 01:15 AM   #4
saplumr
CF Senior Member
Support Corvetteforum!
saplumr's Avatar
Why not just cancel the OnStar if you're worried?
saplumr is online now   Reply With Quote
Old 08-01-2009, 10:56 AM   #5
capicciuti
CF Senior Member
capicciuti's Avatar
Good point guys. I was trying to find out if there is tuning inforation available to GM via OnStar - if there is I would disable and cancel, if not I would keep active. Since the case is we don't know I will cancel. Thanks
Old 08-05-2009, 09:48 PM   #6
amscene
Junior Member
as a tech a lou bachrodt in coconut creek fl, They cannot
amscene is offline   Reply With Quote
Old 08-05-2009, 09:58 PM   #7
da vette guy
CF Senior Member
Quote:
How's business there, i work as a tech at a lincoln mercury store in Pensacola and we have been slow for months....
Old 08-05-2009, 10:38 PM   #8
D.T.S.
Junior Member
On some programmers, On-Star can (not will) interrupt the communications routines during programming and possibly brick the ECM/PCM. Thus the need to remove fuses so that doesn't happen. This won't happen on the C6 though AFAIK.
D.T.S. is offline   Reply With Quote
Old 08-06-2009, 10:58 AM   #9
dennis50nj
CF Senior Member
dennis50nj's Avatar
they told me i had an emissions problem, go to the dealer right away, but i asked them to as i had a service engine light on, so gm could use it to there advantage
dennis50nj is offline   Reply With Quote
Old 08-06-2009, 10:43 PM   #10
Vetteinplano
CF Senior Member
Vetteinplano's Avatar
Didn't you know that GM just purchased 6 covert helicopters equipped with "Tune Detectors". Now the just have to fly over your car and they can tell whether or not it has aftermarket programming!
Maximum All Up Weight: 2,910kg with internal load (6,415 lb)
Engines: Pratt and Whitney PW206B2 twin turbine engine - 457kw (612 shp)
Overall Length: 12.16 m (39.9 ft)
Overall Height: 3.35 m (11 ft)
Rotor Diameter: 10.2 m (33,5 ft)
Fuel Capacity: 560.4 kg (1235.4 lb)
Maximum Speed: 259 kph (140 kts)
Maximum Range (standard fuel tank): 635 km (342 nm)
Maximum Endurance: 3.35 hrs
Maximum Operating Altitude: 10,000 ft.
Microwave Downlink
The new downlink system is digital, allowing PCM Data and information to be transmitted to and from the aircraft and a suspect vehicle securely. The aircraft is equipped with two transmitters for improved reliability, and has a range of over 30 miles.
Star Saphire High Definition Video Thermal Camera
High resolution cameras will give clearer images from further away, allowing operatives to identify a suspect vehicle.
High - definition capacity increases the amount and quality of video evidence that can be obtained to support cancellation of the warranty.
Skyquest integrated navigation system
The system is linked to the thermal imaging and video camera allowing for 'geo pointing' - the camera to be directed automatically to any given location. In addition the 'Tracker' stolen vehicle locating system is linked into the system giving accurate directions to the crew.
Vetteinplano is offline   Reply With Quote
Old 08-07-2009, 05:19 PM   #11
capicciuti
CF Senior Member
capicciuti's Avatar
Vettinplano,
I accept I may be paranoid - but that does not mean I am not followed. I did notice on the monthly vehicle diagnostics report from On-Star that milage, oil percentage and other service factors are reported. I just tried, but so far failed, to find out if any of the factors changed by a predator tune are also captured.
Thanks,
Chuck
PS: The helicopter bit was very funny. I recommend a Global Hawk variant for the loiter time.
Old 08-07-2009, 07:15 PM   #12
Mike02Z
CF Senior Member
Mike02Z's Avatar
In my opinion if you are really that worried about your warranty my advice would be leave the stock tune alone.
On another note I would advise you really should read up on the hand held tuners before plunking down your money. The general consensus seems to be that they are worth very little in perfromance increase for the Corvette. If you really want a tune go to a well known, proven performance tuner. I know you didn't ask that but I wanted to throw it out there anyway. Good luck.
Mike02Z is offline   Reply With Quote
Old 08-07-2009, 07:51 PM   #13
Vetteinplano
CF Senior Member
Hey Chuck,
You should call one of the guys at LG or 21st century in the DFW area. ( there are several other excellent shops that regularly post that are in the DFW area too.)
They should be able to answer any question you have.
Old 08-07-2009, 08:34 PM   #14
Motorhead-47
CF Senior Member
Microwave Downlink
Motorhead-47 is offline   Reply With Quote
Old 08-08-2009, 04:32 AM   #15
Gregory
Junior Member
Gregory's Avatar
Tune away. On Star cannot tell, and there are no complications. I've been doing it for years.
Gregory is offline   Reply With Quote
Reload this Page Can GM spot a Tune via On-Star
Tags
bricked, car, corvette, electronics, find, fuse, gm, hampshire, lg, location, onstar, pcm, removal, tune, tuner
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
