Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-29-2009, 02:03 PM   #1
cobraq8
CF Senior Member
cobraq8's Avatar
Default Scanned my Run, I need analyses...P0300
I have been getting the dreadful P0300. I have done all possible things including a visit to GM dealer with no luck. The CEL Blinks at the top of forth gear from 20:16:21 up to 20:16:25. There is no felt loss in power. For the tune experts, do you see anything abnormal in my attached data? Please Help identifying the cause if any?
07’ LS2 Edit tune by Halltech.
Car CEL Blinks with stock tune as well
cobraq8 is offline   Reply With Quote
Old 08-01-2009, 02:58 AM   #2
racingvett
Junior Member
The little bit of scanner data shown says the tune is the cause, it stinks.
You notice fuel LTFTs running -4 % too rich and at times right side was -9% rich.
This will cause misfires.
At the same time there looks like engine knock ( image is not very clear to see all values)
Worse is at WOT the 02 sensors reporting over 1 volt so pig rich ( should be about 0.850 mVolts)
You need to setup scanner to collect the misfire counters for for each cylinder's current and history counters and then see if the same cylinders always are the ones misfiring or if it is random misfires.
Fire whoever tuned it and get a real pro to do what you are paying for.
racingvett is offline   Reply With Quote
Old 08-04-2009, 02:45 PM   #3
East Tx Muscle Cars
Supporting Vendor
East Tx Muscle Cars's Avatar
Send a message via Yahoo to East Tx Muscle Cars
racing vette pretty much said it all. other than the FT being off most likely wont be your issue, we see cars all the time that are a fre % off each other, BUT the rich issue will do it for sure, your tune is way rich. You also do need to log misfires, see if its all one CYl or all on one side, or all over the place.
But what i would start with is lean that baby out some, and see if that doesnt clear it up for you.
as for the KR is that showing 9* of knock at 20:15:16? thats alot. its hard to see
__________________
STEPHEN COVINGTON OWNER OF E.T.M.C.
Turbos,nitrous,superchargers,Hand Porting and Polishing of heads, fab work, and much more!!!!!
VVVVV---CLICK HERE---VVVVV
WWW.EASTTEXASMUSCLECARS.COM
FINANCING NOW AVI FOR YOUR BUILD!
East Tx Muscle Cars is offline   Reply With Quote
Old 08-04-2009, 03:14 PM   #4
cobraq8
CF Senior Member
cobraq8's Avatar
I was finally able to identify my mystery misfire cause. It was due to a lose coil bolt which did not allow for proper earthing between the coil and the cylinder head cover. As far as the knock retard, it is actually reading 9x10^-2 or 0.09 which I think is pretty low considering the 44 deg. C (112 F) ambient air temp. I was running at .
Thanks for the replies guys
Old 08-04-2009, 03:24 PM   #5
East Tx Muscle Cars
Supporting Vendor
yea thats low then, wouldnt worry a tone abotu that. but i would lean it out, you are rich
Old 08-04-2009, 03:28 PM   #6
cobraq8
CF Senior Member
cobraq8's Avatar
I'm expecting my LSX-R intake in the mail tomorrow. Once it is installed I will have re-tune for sure
Thanks again
Reload this Page Scanned my Run, I need analyses...P0300
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
