Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Scan & Tune
Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette Sponsored by
AMS Performance
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-11-2009, 08:11 AM   #1
Dan Wendling
CF Senior Member
Default Auto TCC settings
Does it make sense to have the Auto TCC Apply settings below the stall speed of the torque converter? I thought that below the stall speed the converter still has a fairly high (>15%) slip ratio. If so, is it safe to engage the TCC at these slip levels?
What is the upside and down side of enabling the Shift Lock so the TCC stays engaged during shifts?
Why allow the Auto TCC to apply in any gears but 5th or 6th? Seems like the objective is to improve fuel economy (i.e. No slip) so who cares about the lower gears?
Unless of course the use of the TCC can improve the performance under acceleration (>50% Throttle Position).
All comments welcome!!
Dan Wendling is offline   Reply With Quote
Old 07-11-2009, 08:23 AM   #2
pmj341
CF Senior Member
St. Jude Donor '08-'09-'10
Support Corvetteforum!
pmj341's Avatar
Send a message via AIM to pmj341
thesubfloor-Christopher can help you,send him a PM
pmj341 is offline   Reply With Quote
Old 07-13-2009, 10:50 AM   #3
ian@thetuningschool
Supporting Vendor
ian@thetuningschool's Avatar
Hi Dan,
The TCC can improve your performance only if you have to the power to push through the converter, even the stock cars don't have the power to push trough the converter, only reason gm locks the converter from 2nd gear is because of fuel economy. I would set your tune up so it only locks under the cruise phase to keep the fuel economy, around 31% throttle up set it so it unlocks. With the converter unlocked it slips, but u get a torque multiplication because of this and faster throttle response. When u get around 500 hp you can start locking the converter to gain so hp and tq.
Ian
ian@thetuningschool is offline   Reply With Quote
Old 07-13-2009, 11:08 AM   #4
pmj341
CF Senior Member
pmj341's Avatar
Quote:
Originally Posted by ian@thetuningschool View Post
Hi Dan,
Ian
phil
Old 07-17-2009, 12:24 PM   #5
Ragtop 99
CF Senior Member
Ragtop 99's Avatar
With a stock or small aftermarket converter, you can just leave it unlocked. If you put in a big stall (e.g. 3600 or higher), the amount of slip may make you want to use lock-up in 4th and possibly 3rd, just because it can get tiring around town.
Ian's 31% for unlock was right around what I used when I had big stalls.
Ragtop 99 is offline   Reply With Quote
Reload this Page Auto TCC settings
Tags
auto, lock, shift, tcc
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS 1995 Convertible Artic White Automatic 41K miles Lone Ranger C4s for Sale/Wanted 9 09-15-2005 07:34 PM
A4 trans problems - help/advice please! kawoods C5 Scan & Tune 12 06-19-2005 01:42 PM
A4 transmission problems please help! kawoods C5 Tech 19 06-17-2005 07:33 PM
Need input on 4+3 swap, please! want2drivemy85 C4 Tech/Performance 11 03-07-2003 01:45 AM
[Paging]: Craig Marcho (4+3 Chip Question) scorp508 C4 Tech/Performance 16 10-27-2001 02:58 PM
Crash course in custom chip burning... First impressions... Nomar116 C4 Tech/Performance 16 10-06-2001 11:56 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
