Quote:
Originally Posted by BAIN
So I should lower my mph until I get the shifts to occur at the rpm desired?
Yes, but you also need to make sure you have the correct tire size and gear ratio in your tune first or else it won’t respond to MPH adjustments either.
As an example, last night at the track I wanted to lower my 2-3 shift by a few hundred RPM so I dropped the MPH value a bit but the shift point still didn’t change. What ended up causing that was because I was running a smaller drag radial but forgot the make the adjustment in my tune so even though I wanted it to shift at 53MPH it kept on shifting at 58MPH.
Once you do get those values entered correctly the car will shift based on MPH adjustments.
Christopher
