C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Slicks or drag radials?
Old 02-26-2009, 10:50 PM
NandoZ06
NandoZ06's Avatar
Default Slicks or drag radials?
07 Z06 750rwhp..cant get it to hook on the 1/4 mile strip..Look like a snake going down the track..
Old 02-27-2009, 02:21 PM
patton
patton's Avatar
St. Jude Donor '09
try the DR if you smoke them go to slicks...and get ready to order trans/rear parts
Old 02-28-2009, 12:04 PM
NandoZ06
NandoZ06's Avatar
What! Rear end parts...I heard these rear ends are rated up to 900ft.lbs of torque..i am bout 770ft.lbs..
Old 02-28-2009, 08:02 PM
TinSecondRice
Support Corvetteforum!
TinSecondRice's Avatar
St. Jude Donor '08-'11
I would go with a set of MT ET Streets
Old 03-01-2009, 10:38 AM
0Brian@RPT
Former Vendor
Brian@RPT's Avatar
The MT ET Street Drag Radials works really well and are a very soft compound tire.
Old 03-01-2009, 03:12 PM
NandoZ06
NandoZ06's Avatar
What about wheel size on those MT's Street DRs? 16 or 17s?
Old 03-01-2009, 05:48 PM
SETc6
SETc6's Avatar
they need to make MT for 19's i love the new Street drag radial II
Old 03-09-2009, 04:34 PM
Greg MFn Z
Greg MFn Z's Avatar
St Jude Donor '14
Is the street drag radial II better then the first one ?
Old 03-09-2009, 05:32 PM
NandoZ06
NandoZ06's Avatar
dont know but i jus picked up 2 MT drag radials 305/45 18..i had the hoosiers 325/30 19..those things didnt hold up on the dragstrip..
Old 03-14-2009, 05:14 PM
MLCZ51
MLCZ51's Avatar
Default i agree..
I LOVE MY MT'S
Old 03-21-2009, 11:27 AM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
17" MT Et Street radials are great on C5 Zo6 rims...they look a little thin on the car but hook like a ****. You can't put the wheel weights on the outside 1/2 of the barrel or they will hit the brake calipers.
Or go with 18" MT ET Street Radials, they are wider at 315/s and look better...
However, the short (25") 17 radials will give you a nice gearing advantage to get you out of the hole faster.
Old 04-06-2009, 08:30 PM
siffert
siffert's Avatar
Can you explain to me how DR' work as they get worn down? I always
thought they got better so far as hooking as they wear down to the point of near slick. However, I have noticed for awhile that I have a case of my auto 1-2 shift spinning tires that I know is costing me a bit of time. While my 60' launches are improving as my tires wear, it this because launches dont hit as hard on the rubber as the 1-2 shift?
Did your launches and 60' get better right away with your new MT's?
Old 04-06-2009, 10:15 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
I think the age of the tires and number of heat cycles affects traction, the older they get and the more burnouts the worse they get, even if they have tread.
I find nothing is better than a fresh set of new dr's. I immediately dropped .2 to .3 when I strapped a set on.
And blew my rear and trans to smithereens! But that was from getting ever more aggressive with my launches and launching hard on an untested track and spinning to a slight wheelhop on my final run. The wheelhop was no worse than other infrequent wheelhops but this one did me in.
Old 05-03-2009, 11:48 AM
Chris 2002
Chris 2002's Avatar
Default tire???
hello, im having a hard time getting my car to hook up. I have 305/30/19 nitto's. I have 430rwhp w/390 gears. I like my 19's but if they can not hook up I need to try some thing new. Could you tell me about it and what you found? thank you
If I go with the 18"s what size rim should I try and would the 345/???/18 fit? Its not a Zo6! I might be able to get some 18x12 nock offs.. Thanks for your help.
Old 05-03-2009, 03:37 PM
EdwardETraylorIII
EdwardETraylorIII's Avatar
A mod should move this thread to the FI/Nitrous area.
The new Mickey Thompson ET Street Radial II in the 345/18 (Part number 3788R) size is what you need. This will cure ALL of your traction issues at 700 RWHP.
Old 05-03-2009, 11:26 PM
NandoZ06
NandoZ06's Avatar
Edward,
as soon as the set i picked up 305/45/18 are worn out, the 345/18 are going to be my next purchase, although the 305's help my time by 1sec. but still get a lot of wheel spin in 1st and 2nd. The 345's should help.
Old 05-15-2009, 11:43 AM
blackbird345
blackbird345's Avatar
Can the 345/18 fit on the regular c6 or would you need Z06 rear fenders?
To Slicks or drag radials?
Old 05-15-2009, 01:51 PM
EdwardETraylorIII
You'll need the Z06 fenders.
Old 12-13-2009, 10:21 AM
MADDOX45
MADDOX45's Avatar
Default hooking up
drag radials is better than Street Tires
Slicks are a little better than DR
WEIGHT distribution is worth more than Either
Shocks have to allow some front end lift, and be dampened when falling
C5 750 HP TWIN TURBO
GET A DTE BRACE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I BROKE THE FLEXPLATE, BUT NO TRANNY OR REAREND YET
Of course it will happen sometime later!!!
Old 12-22-2009, 05:01 PM
jmudreamvette
jmudreamvette's Avatar
Just went to the drags this last Sunday, My friend has a STS twin turbo on his Z. 725 RWHP with the new MT ET STREET 345's / 18. His first run he spun bad. I told him to do a good burn out, really heat them up. The second run he really hooked up, That was coming out at 4000 RPM. Ran a 10.97 Last run he was at 4600 RPM and ran a 10.71! They DO hook up if you heat u'm up
Quick Reply: Slicks or drag radials?
