C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
How to reduce A/F at WOT HPTuners
Old 12-31-2007, 03:25 PM
Hooked4Life
Hooked4Life's Avatar
Default How to reduce A/F at WOT HPTuners
I have an 07 Vette. The tune is pretty much where I want it, but my WOT AF is about 12.0-12.2, I am looking to get to about 12.6 for now. I cant seem to figure out how to just reduce the fuel by about 5% during WOT. My MAF is tuned perfect, giving me 0 trims almost all the time, so I dont want to screw that up. I am just not familiar enough with the tables to know where to tweak the fuel. I am not interested in changing to speed-density tuning. I want to conquor this first.
Old 12-31-2007, 04:12 PM
0ZO6PARTS
Supporting Vendor
ZO6PARTS's Avatar
Power enrichment tabels.
Old 12-31-2007, 08:55 PM
Hooked4Life
That is where I set my AF to 12.6 already. My actual reading from the wideband is about 11.9-12.2, looking for the right table to tweak the actual to match the commanded.
Old 12-31-2007, 09:18 PM
edcmat-l1
edcmat-l1's Avatar
Sounds like you have the right approach. Most people skew the PE to get XX A/F ratio. The right way, the way it sounds like you're trying to do it, you set the pe to MATHEMATICALLY be what you want the pe to be, and then scale your MAF. If you need more help, post or pm. You can change the WOT fueling without affecting the part throttle stuff.
Old 01-01-2008, 12:42 AM
Sparkman
Sparkman's Avatar
Default cat overtemp?
Your condition may be result of "cat overtemp" protection. This function adds fuel when the calculated temperature of the catalyst is exceeded.
Old 01-01-2008, 09:33 AM
edcmat-l1
edcmat-l1's Avatar
Thats true too, but I've turned a bunch of em off, only to make no dif in the A/F. Some do, some dont. Never seen any kind of rationality behind the differences.
Old 01-01-2008, 09:45 AM
baf2000_1
baf2000_1's Avatar
This sounds like the MAF is reading too high thus adding too much fuel. Looks like VE table may need adjustment.
Old 01-01-2008, 12:01 PM
0foff667
Former Vendor
foff667's Avatar
VE coefficient table(s) have little or no say in fueling at wot when the maf is still in use & functioning properly.
Old 01-01-2008, 12:04 PM
0foff667
Former Vendor
foff667's Avatar
COT enrichment would show up as a different afr/eq ratio which you should be able to scan, not to mention a status bit so you could always tell when COT is coming into play.
Old 01-01-2008, 12:06 PM
0foff667
Former Vendor
foff667's Avatar
Your maf table is your main wot fueling table so unless you want to fudge the pe table you'll need to tune it for your wot fueling so commanded=actual
Old 01-01-2008, 08:34 PM
Hooked4Life
COT is disabled for now, so not an issue.
Thanks for the advice all, these C6 ECU's are pretty daunting at first, but I am getting the hang of it. Taking it one small change at a time, and log, log, log.
I made a few small tweaks to the upper MAF, will post results.
Old 01-03-2008, 08:06 PM
Hooked4Life
Worked great! thanks all.
To How to reduce A/F at WOT HPTuners
Quick Reply: How to reduce A/F at WOT HPTuners
