Will this setup hit 10psi?
2006 c6 z06 427 dart engine with ECS 2200H/D. I am putting this all together now. Came with a 3.6 driven pulley and 10% overdrive crank pulley. Will this hit 10psi do you think? Or should I pulley down a little? Would like to hit 10psi at a minimum to start off with. End goal is 1000 wheel, should I upgrade to the 2200R to before installing? I'd rather not overspin a blower.
And any recommendations on transmission or differential? No launching, street car only, but 120k miles on existing trans and diff.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
You will make right around 9-950 rwhp with that blower. You are currently going to have a max RPM of the blower at 7000 rpm of 54,4444 so you could pulley down a little since max RPM of that blower is 60k. You could go down to a 3.25" pulley which would put you just tick over 60k at red line.
mgrotel (03-06-2024)
