LS9 MAP voltage for boost pressure?
I swapped out my stock LS3 map with an LS9 map so I could read pressure with my Novi 1500. Can I tap one of the three wires coming off of it and feed it into my analog 2 on my Aeroforce Interceptor gauge? Would anybody know the slope and intercept for it?
Thanks for the thoughts!
Quick follow up. I think I found that the linear output for the LS9 MAP sensor is 312 at 5V, so I think the slope would then equate to 62.5. It's published that the intercept is -11.2, so I guess I can start from there and see what happens. My assumption is that at idle, I should see a negative number, implying that is vacuum? Does that check out?
yes, thats a good starting point, probably from the original tune. however i ended up with a bit different values after checking how it is (ls1). like that it underreported by 4-5 kpa with engine off. the original setup underreported by 1-2 kpa. btw, these sensors are not very accurate, +/- 3% is best (out of memory) and gets worse depending on temperature. mine had a huge glitch at 40 kpa i believe.
