Can you block off only the passenger Fuel Pressure Regulator?
OEM z06 fuel pump
stock regulators on both housings
I am wondering if I could just bypass/block off the passenger fuel pressure regulator and keep the driver regulator oem?
I don't think it works like that the, regulator in the DS tank controls FP to the engine and the one in the PS tank just controls the siphon pump to keep fuel moving to the DS tank. so with out it I'm not sure it would still work. We do change them to transfer at lower pressures when wanting to run lower than factory FP. GL but I guess you can do what ever you want.
The following 2 users liked this post by inspector12:
Drift Vette (06-23-2023),
Josh@AandASuperchargers (06-29-2023)
