Big Single Rear Mount Revamped
Awesome build man and even better that you're still rowing gears!! Looking forward to following your progress
I hear you on that one, been there plenty of time and years lol.
Thanks I appreciate it. I’m not sure if that’s a good thing at this power level. As long as it doesn’t do some crazy wheel hop from a roll and I don’t no lift shift it hopefully it’ll stay together. 🙏
A few pictures from the engine builder. I can honestly say that this will be the first time EVER in it’s life that this LSX block/engine will actually be built correctly. Sad as hell but it’s the truth. Looking forward to what this motor wants to pump out steam wise.
Thanks.
Thanks I appreciate it. Exhaust is about to change a little bit. Switched from stock LS7 manifolds to Kooks 2” long tubes, changing the piping under the car slightly and the cam this go around is quite a bit bigger so I doubt it sounds the same. But here is the old engine combo and the way it used to sound right before TX2K21.
Awesome build! The downpipe/wastegate dump tube routing is clever; I like that you stuck with the general location of the stock tips.
Well thanks to Jayyyw I’ve decided to cut this car up some more lol jk. Got talked into making the swap from 325/50/15’s to the 315/60/15 radial pro’s. Got the fender liners out today and I took my rear coilovers out and checked them and raised them up about 1/2”. Hopefully all I’ll have to do is trim some battery trays on each side and the big boy tires will clear. I’ll call this my donk setting. 😎
#33
I went from hazing the tires at 1200 in second and 1300 in 3rd to dead hooking 1200 in second and 1500+ in 3rd. Probably the single greatest thing you can do, traction wise. Effective gearing changes a bit but just brake boost it harder or put it on some rolling anti-lag.
#35
Nice build, I was following the build several years ago. Glad you getting it going again, good luck.
I thought Jorge worked for for JMS? I went over there a few times to help them with problem electrical issues. Shop was full of cars but not much work getting done.
Looking forward to seeing the final results of this great "different" build.
#36
As far as Jorge and JMS goes, Jorge did the smart thing and split ways from Joaquin and that circus a while back. JMS/Joaquin Alpizar is a freaking joke. That dude is nothing but a scam artist looking to take advantage of people any way that he sees fit. He constantly lies, takes parts off of other peoples cars to finish builds and it gets a lot worse from there. He never takes ownership of ANYTHING, he’ll either blame the customer or the tuner. I could start my own thread from my own personal experience with him it’s pretty bad. He “built” two LSX motors for me. One motor made it 500mi and the next almost 800mi smh. So if you wanna know why there’s not much work getting done at JMS that’s probably why lol. Joaquin spends majority of his time bringing cars to and from Mexico letting them sit in the overflow lot and running around on his wife across the border. Can’t possibly get much done when you live like that. 🤷♂️
schpenxel (12-20-2021)
#38
jayyyw (12-22-2021)
#39
My friend is in the 2.7-2.8 range 60-130, ***** absurd, doesnt launch hard but comes on like donkey kong and traps 175+.
#40
