Where are people mounting the Alky Control Meth controllers, etc?
I am replacing a non-operational Cool Mist system with the AlkyControl MAP system. This kit has the controller and some other electronics. I'm curious if everyone is just mounting all of this in the glove box or where? Pictures of your installs if you have them.
Thanks - Todd
Thanks - Todd
Controller fits perfectly in the ashtray cutout and the door will still close over it. The big box is zip tied up under the dash by the steering column.
ToddEdge (04-16-2020)
ToddEdge (04-27-2020)
Did you cut out the back of the ashtray to get this to fit? I removed the ashtray insert and dremeled down the case a bit to squeeze it in To the ashtray housing but the ***** just miss allowing the door to shut. Is it possible for you to take a few pics of the cutout? Don’t bother if it’s too much work.
Glovebox. I don’t have a picture handy.
Just double sided taped under steering area.
doomi (05-04-2020)
I didn't took any pictures but I know one thing, if its not hidden and not neatly installed, I was not going to do it, I completed my installation yesterday and after it was completed, I was smiling.
I installed the pac under my dead pedal with all wiring under the dead pedal, the map sensor was installed next to the pump and the remote controller is both side tape under the steering panel on the driver side just a little above the hood pull.
The best part is I drilled 2 holes to the side off my dead pedal to adjust the pac controls if needed, that is the turn-on and initial on the pack for pump speed.
Funny I did the same and maybe around the same time also, lol. He did , I eventually did it, the only question is I noticed a IAT sensor in my kit but never saw where to install it, I believe since I already had a factory IAT sensor, I don't think it was important.
