CAI options for LS7 Procharger kit?
Looking at the air intake it looks rather restrictive. I saw Dallas performance makes one. Does anyone else? And is it worth the swap? Car only makes 570rwhp I’d like to get a little more out of it if possible. It’s a stock Z06 with the base Procharger kit and borla 3” X pipe and stinger axle back.
A&A also makes a larger inlet tube, but you will likely need a shortened radiator to make it fit. Other option is to just put a smaller pulley on the blower.
Ya I’m not looking into a smaller pulley at this time. Would just like to optimize what’s on there and go from there. I saw the A&A one but yes it looked like it needed other mods to fit. Are those the only two options?
LemansC6 (03-04-2018)
40-60rwhp is common with new intake. PC has a "race intake". I would just fab your own or do the DP.
Yes, it will add 2+psi of boost, and add a lot of power, so you need a retune, and possibly more fuel pump/injectors/octane.
I have the DP one on my car. It picked up like 40 wheel and even more torque when I did the swap years ago.
