meth questions
meth questions
i have a c6Z lg blower cam AA kit with 3.6 pulley AHP heads putting down 650rwhp. Was at TX2k17 when i dyno at MTI and Billy advised me to seriously consider adding meth when i put my headers on soon (told him i was adding them very soon to push the 700mark)
My concern and more just from lack of knowledge:
am i correct in saying that meth spray control is added per boost level. meaning that in low/no boost (cruising) the meth consumption is very low?
what other kits are out there besides ECS kit?
I live in the boonies where we are restricted to 93 pump gas so i don't have E85. I also use my car to make several long drives.. (drove from New Orleans to TX2k17 this weekend) how long does the windshield wiper juice container of meth last?
anything i should be concerned or know about cars on meth? ive never had a car that needed it.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
When you are not in boost it uses 0 meth, and you are correct that it ramps up with boost. Most people get 2-3 tanks of gas out of a tank of meth, but that all depends on your use, a heavy foot will use more.
Meth kicks on a set PSI and ramps up with PSI assuming you are using a MAP based controller. You can use a MAF based one that ramps it by maf values too. So you use no meth at all under the start point of typically 3-4psi.
It can last 6 months or 30 minutes. It only sprays when you are on it. I've gone 3 months or filled up same day. At 1/2 mile I made ~10 passes before I had to add more.
Can't go wrong with an Alky Control kit.
You'll make more power and do it safely as long as it's tuned properly. Very easy to maintain. If you don't drive like a lunatic on the streets the meth will last for a while. Just buy a 5 gal jug and it should last you a few months unless you run the car hard often.
The instructions, in my opinion, are not good. All of the information you need can be found in the instructions, plus a little extra common sense. Fortunately, lots of people are running the kit, so if you have questions, you can contact Julio (Alky Control), ECS or ask here on the forum.
If you don't plan on raising the boost. You don't experience heat soak or any time of time retard.
There's no real reason for meth other than a mental hurdle.
The A&A kit. Supposed to kick belts less and have a better intercooler. That's why I went that route (supercharger head units are nearly identical as Vortech makes Paxton)
You also not correct in claiming that stock boost levels don't cause high enough IATs to reduce ignition timing. Maybe that would be true if you lived in a cold climate, but it's not that hard to get IATs in the area where timing is reduced. You can do it on a stock car.. that's why the tables exist to tune it.
I'm not saying that everyone needs meth. I didn't run it for a year. I could tell power was down in the summer compared to spring fall though.
If you aren't pulling timing after a 1-4 gear pull, even at 5-6psi on any kit, you have a serious tune issue.
Meth is very helpful, even at low boost.
ECS and A&A intercoolers are comparable and both have great belt systems.
Could you explain why he have to pull timing if make a 1-4 pull and his IAT is still under acceptable range lets say 130 F ?
Patriot Six (03-21-2017)
If your IATs with any centri kit are below 130F after a full 1-4th gear pull, you have some crazy magic or running the car in <50f outside temps.
meth is a game changer on these cars. more power and more reliable. i can't see any reason not to do it and you can have meth delivered right to your door from hyperfuels.
We only use and recommend 100% meth.
I have often said that it's god's gift to high HP street cars, race gas on demand!
c6moneypit (03-26-2017)
As for your previous question about ease of install, it took me about 8 hours to do (Alkycontrol kit) and was my first time. There is nothing that is hard to do at all, it's pretty simple mechanical and electrical work. It's just time consuming since there are multiple things to do.
I did pull the fender completely off, so I'm sure that added a bit to my time too.
I can't really comment on usage since it really depends how much you drive and how much you're in boost. I'm probably 6-8 months in and have only used about 2.5 gallons. I probably use a bit less than average since about half my time driving the car is occasional commuting to work in fairly heavy traffic where I'm using nearly nothing.
The Alky control kit is by far the best kit for these applications, anyone that says something negative about meth usage is basically closed minded....Period! There really is no down side to using meth and for those that say what happens if the pump fails or you run out... What happens if you run low on fuel and burn out a motor? What happens if you have any other type of failure and break something... Same ****!!! You fix and go on, NOTHING is foolproof but meth has a great many benefits and most especially on boosted cars, I will never run with out it! I also know how to maintain my system and inspect it, the very same way anyone with a high performance car should inspect the operating system's on it.... Get the Alky control and have fun!
