SINISTTERC6 awakening the demon
#502
Good news is I get a fresh engine:
Bryant crank was the lone survivor of this mass casualty, reinforcements are already on the way. John Simpson and GSpeed building motor 4, if it's like their fab and wiring should be the last one the car needs.
Dart ls next pro series block
Diamond ls race pistons
Callie enforcer rods
ORings, Copper head gaskets
Top end did well but the springs, intake valves and rockers will get swapped for units more oriented in longevity and not drag racing.
#505
Congratulations on your Lambo Nick but I'd take Bam Bam any day over that car. Bam Bam was a labor of Love and had personality for days! You'd put your heart and sweat into that car and it showed!
It's kind of like Sinister is doing with His C6! He Loves the platform and His car and wants to make it one of the fastest STREET driven C6's on the Planet! Much Respect for that!
I do have a question though and am surprised to see that the piston's aren't gas ported like the old ones (unless they just haven't gotten around to drilling them yet but I though that they'd come already done).
Thanks for keeping us posted and I hope that everything turns pout like you want it to.
#506
I'm Sorry to hear about your engine melt down but on the bright side, you'll get a fresh, stronger motor. It takes quite a bit of force to bend a connecting rod like that! OUCH! What happened to it? Was it just too much power and it reached the parts limits?
Good eye, theyre horizontal gas ports so less change to clog up on pump gas
This was as 4psi~ 1000hp, based on logs and healthy piston appearance it looks like the gasket gave and it hydrolocked
If all goes to plan ill be calling the project SINISTT3RC6
#507
[QUOTE=FreddyG;1607683915]That's a Nice looking car that I'll bet performs on another level but (to preface this though and this is my opinion), TT Lambo's are quick/fast/whatever but anyone that has the income can buy one and to me, are not that special (I'm one of those that can't afford one but even if I won the lottery, I wouldn't want one, so I'm good there ).
Appreciate props on Bam Bam!
Yeah that in the day were 1K or more was unheard of.
#511
Thanks for the compliment!
You were making 1000hp on only 4 psi? That's an efficient setup! Are you o-ringing the heads or block to go with those new copper gaskets? What head studs are you using?
[QUOTE=NICK YOSKIN;1607684427]
#512
You're Welcome and Thanks for the good eye compliment! That makes sense about the new gas ports and Thanks because I learned something new today (I didn't know that they could do horizontal gas ports).
I'm not sure on studs or which components are getting the receiver grooves but I'll post up when I have the info
jayyyw (04-04-2024)
#513
To claify made 850 at 4spi waste gate,this happend with it set to 8psi at 5k rpm around 1050hp. The benefit to the rear turbo setup was the efficiency and weight over rear tire. It was hitting 1500+ at 23psi back in the day
jayyyw (04-28-2024)
#516
Nobody is putting money into C6's though. Yes, here and there, but Vipers, GTR's and R8/Huracans are where the big money is going. The chassis is great but they just don't hook at higher power levels. Vipers at least have the aero and the rear tire is basically behind the driver seat, which helps.
#517
#518
