C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
novi 1500 vs novi 2200
Old 08-10-2016, 01:03 PM
MBB
MBB's Avatar
Originally Posted by neverstop
I'd bet the 1500 will have better torque curve and more power under the curve than a bigger head unit spun slowly
That was my understanding and reasoning.
Originally Posted by realcanuk
Tapping the pan is no big deal while you are doing the install.
No, but it makes for something to explain once you go to sell your car.
Old 08-10-2016, 03:39 PM
winters97gt
winters97gt's Avatar
Just get another pan.
Old 08-10-2016, 03:47 PM
algZO6
algZO6's Avatar
i have had both, get the oil fed 2200 like doug said.
Old 08-10-2016, 04:43 PM
C U IN REARVEIW
C U IN REARVEIW's Avatar
Probably should tell them anyways...wouldn't you want to know? I would just sell the car with the blower on it.....demodding is a pita
Old 08-10-2016, 05:59 PM
Dyekid04
Dyekid04's Avatar
Think its going to be 1500 , with meth kit and maybe a dampner? My heads and cam and exhaust will probably need the restrictor plate removed to make 10-11 psi on the standard pulley. As long as i can make 750 RWHP , ill be more than happy. Thats all i want is to drag all these damn Forced induction 5.0 and bosses and 5.8 GT500's is that too much too ask??? Lol toooo many of them around here
Old 08-10-2016, 06:01 PM
Dyekid04
Dyekid04's Avatar
Anyone using a dampner pulley if so what are you guys rolling with? I figure if i have to pull it off again.... I should probably get a dampner and gave it pinned? What size without messing with the boost.
Old 08-10-2016, 07:49 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Cheapest option is probably Summit C2501 which comes in stock size.
ATI/IW are obviously nicer options
Old 08-10-2016, 11:00 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
That was my understanding and reasoning.No, but it makes for something to explain once you go to sell your car.
Never consider that in what I do to my car. Won't ever demod it anyways.
Old 08-11-2016, 07:07 AM
slow goat
slow goat's Avatar
IW 10% overdrive pinned.
Old 08-12-2016, 10:46 PM
stephenpen
stephenpen's Avatar
I was in the same boat and went with the 2200. I was very surprised how much power it made on 12lbs. 3.60 pulley it makes just over 800whp on my SBE L96.
I figured for the extra $300 why not get the bigger blower. The cost to upgrade it later wouldn't be worth it. I find myself never taking my motor to redline. It's just not necessary.
Old 08-13-2016, 11:49 AM
Dyekid04
Dyekid04's Avatar
You running a full 8 rib system? Or just the 8 rib balancer on a 6 rib system??
Old 08-13-2016, 02:52 PM
C U IN REARVEIW
I'm thinking similarly. ....I am going to pulley down my A&A ti trim and am thinking of just going straight to the 3.4" (4" currently ) so I don't need to rev it as high to get the power I'm going for (650+ whp)....?
Old 08-13-2016, 04:51 PM
  #33
GeneSch
GeneSch's Avatar
Originally Posted by silas1234
I just made 771/654 on 12psi 2009 auto car with a 1500. Btr cam, kooks headers and meth.
https://www.facebook.com/WreckedVett...8751857570603/
How much timing are you running?
I have the 1500 on a 6 rib. I like it because its simple. No oil lines to mess with. You can remove the blower in 15min if you need to work on anything that it may be in the way of and there is zero mess. You should be thinking tires and clutch before you go 2200.
I'm at 750/650 on a mustang dyno with 14deg of timming. 12#'s, Meth ARH 1-7/8 and a BTR small blower cam. Not much over stock lift. This was on a 90deg day.
Not sure why people need much more. This car rolls out and stll drievs stock.
Old 08-13-2016, 05:10 PM
  #34
stephenpen
stephenpen's Avatar
Still on the 6 rib. Every once and awhile I notice some belt slip. I definitely need to upgrade down the road. But I'm not a racer it's a street car
Dyekid04 (08-13-2016)
Old 08-13-2016, 05:24 PM
  #35
Dyekid04
Dyekid04's Avatar
You running stock balancer just pinned? Im thinking since i have to take all the **** out to pin it i might aswell just upgrade it too for future 8 rib maybe.
Old 08-13-2016, 05:25 PM
  #36
Dyekid04
Dyekid04's Avatar
You on stock bottom end LS2? If so you arnt worried about 12 psi being too much pressure?
Old 08-13-2016, 06:52 PM
  #37
schpenxel
schpenxel's Avatar
St. Jude Donor '15
The more the merrier
I'm running just as much.
To novi 1500 vs novi 2200
Old 08-14-2016, 10:57 AM
  #38
stephenpen
stephenpen's Avatar
Yes I'm just running a pinned 6 rib balancer. I didn't even think about at the time to put on the 8 rib balancer.
Old 08-14-2016, 12:34 PM
  #39
winters97gt
Need to get away from this PSI thinking thing. It's power/lack of octane/heat/detonation that kills these motors. Guys have lived fine at 800+hp while others don't live at 600-700.
Old 08-14-2016, 01:30 PM
  #40
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I don't know why people don't get this. PSI is pretty much completely irrelevant unless you are talking about pressure a hose clamp holds, or something like that.
Quick Reply: novi 1500 vs novi 2200
