Overall Tire Diameter
Does anyone know the minimum and maximum overall tire diameter for a C6Z?
I bought 18x12 rear wheels and looking for drag radials. I don't want the tires to rub the inner fender liner when it squats or goes over bumps.
schpenxel (05-26-2016)
I run a 345/35/18 drag radial on my 18x13 and they are perfect. 28" tall so gearing is great with big power, 170+ mph at 7000 rpms in 4th gear and only rub if it is strapped down too much on the dyno. Mickey Thompson and M&H both make the size and hook great for a 18" rear.
I run an 18x12 wheel and have a widebody conversion. Running M&H racemasters in 345/35 which comes out to around 27.7" Im also pretty slammed on bilstein suspension, can fit a finger between the wheel well and tire. Doesnt rub under 750hp accelerations. I would think you would be fine with the same size, especially if you're not lowered.
There is no set number. Depends on how low or high you make the car. What shocks, what springs, road conditions, etc.
If it does rub every once and awhile, who cares? Fender liners are cheap.
CI GS (05-26-2016)
BIGMAC
Received 1,194 Likes
St. Jude Donor '15
The ratio of front to rear is what matters active handling/ABS/TCS wise
I run 28" rears and never had an issue, but do rub on bumps.
Like I said, it all depends on the overall setup. You can rub a 26" or never rub a 29". Depends on how low, and how stiff the suspension is, and how you use the car.
St. Jude Donor '15
Heck if I know
It's around an inch...some cars are pickier than others. I run a 1 inch stagger on street wheels and my track wheels are 26" front and back. No issues either way.
I see guys on here that are running 28" M&H rears (which are actually ~27.5") with ~26" fronts, and they claim to have no problems with AH. Sounds like it's hit and miss. Perhaps those that don't experience any issues are running with AH/TC disabled?
I'm about to find out myself...
I run a 26/28" combo.
It depends on what you mean by miss. I get some active braking warning slowing down some times, but it doesn't mess or do anything bad. If that bothers you, don't do it.
CI GS (06-01-2016)
"Slowing down"? What do you mean by slowing down?
I am trying to decide between Mickey Thompson E/T R, Mickey Thompson E/T SS, and M&H Racemasters.
Which one would you guys recommend for roll races from 55 mph-180 mph?
Basically 1/2 mile events at airports (SlipStream in PA).
Do you only run 1/4 mile at the drag strip with those tires, or do you also run 1/2 mile roll races?
And what's the highest speed you've taken those drag radials to?
