LS2 paxton 1500=806rwhp
LS2 ECS Paxton 1500=806rwhp
Today I must say I was very impressed.dyno'd 806 to the wheels on 16lbs and meth.i have a forged ls2 with all the goodies and a ECS 1500 kit.My injectors maxed out as well as my maf and blower lol.Sometime next week my tuner will spend a little more time with the car for a speed density tune.Just thought I'd share with you guys.!
Heres a dyno vid:
Dyno chart:
Heres a dyno vid:
Dyno chart:
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
Nice job guys!!
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
I assume is a stock stroke? 16 psi? Did you pulley down even further than the 3.25? Those are some strong numbers, and like the others mentioned, please list all your mods.
Thanks guys!!
Yea I have the m6 with a stock stroke.I had a belt issue as well.LMR got that fixed for me..I didn't have time to mess with it..I payed a little more,but everything's done right on the car.It ended up needing a shim kit.I did pulley down to a 3" from the 3.25" here are my specs for you guys.I have a for sale thread for the car that's still around here.I let that die and changed my mind on selling it.
Engine:
LS2 Engine Block, balanced, blueprinted, honed to 365 cu in (6.0L)
Compression ratio: 10:2:1
Indexed and trued LS2 crank, Callies Compstar 6.125" H-Beam Rods w/ARP 2000 7/16" bolts, Wiseco Forged Pistons 4.005" X 1.300" x -11, tool steel wrist pins and anti friction coating on skirts, Total Seal top rings 1.2 stainless, 1.2 napier, 3mm oil.
Bearings Main, Rod: Clevite H Series. Cam: Dura Bond one piece.
Fasteners: Main cap; ARP studs. Cylinder head: ARP Pro series 12pt studs.
Heads: LS2, resurfaced, re-lapped valves, 64cc chamber volume.
Head gaskets: GM MLS 6.0L. Lifters: GM LS7.
Push rods: Manley 7.400x5/16"
Camshaft: Custom comp cam 229/243 .61x/.62x 115 lsa
Timing Set: N motion LS2 4x Double Roller,torington bearing and nitrated gears.
Valve Springs: PAC Dual with Titanium Retainers.(Seat 145lbs, Open Pressure: 425lbs.)
Installed height: 1.800", Coil bind: 1.090".
Valve Seals: Viton w/steel jacket.Oil Pump: Melling HP Ported.
Paxton 1500 oil fed
8-Rib Flip Drive (8 rib SFI pulley with ARP bolt and machined keyway)
A&A Passenger side feed ram-air intercooler (Air/Air), Turbosmart Blow off valve
Alcohol Injection Systems Methonal Injection, digitally controlled(boost referenced,starts at 4PSI), with 1.8 gallon hidden tank in driver's side cubby hole. Dual 10lbs/hr nozzles (methonal tank needs to be refilled every 4-6 full tanks of gas).
Mcleod RXT twin disc,balanced aluminum billet Flywheel with remote bleeder
Rebuilt T56 transmission; new synchros, solid synchronizer keys, steel shifter forks, compressed carbon blocking rings, bronze shifter bushing, bronze fork pads
Upgraded rear diff (300M half shafts)
:thumbsup:
Engine:
Paxton 1500 oil fed
:thumbsup:
I eventually want to forge my LS2, lower the CR and up my boost a little, maybe 14 or 15 psi max. I want to keep costs down and reliability high. I noticed a lot of stock parts like heads, crank and bore. Did that help with the costs and do you expect this motor to last as a daily driver? I'm at 625 rwhp right now on a relitively stock motor but hoping for 700-750 max down the road.
Yeah, that's over spinning it about 8% at 6800rpm. Definetly as far as I'd go. It's a bad little blower though, made 850rwhp/800rwtq with the 3.125 pulley on it.
Nice!ive been contemplating for awhile to upgrade to the 2200r...but I think I'm guna end up selling the car and getting a c7zo6 in the near future.im happy where the cars at right now and how it runs.what kind of power you making?
I don't know how much it is making, I'm breaking in the engine now and then the guys at Lethal in SA are gonna tune it (they've done all the work on the car)... These 800rwhp 1500 setups have me a little anxious!
