C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
The new ProCharger F-1A-94 is HAULING the mail.....
Old 10-14-2014, 03:34 PM
0ProChargerTech
Former Vendor
ProChargerTech's Avatar
Default The new ProCharger F-1A-94 is HAULING the mail.....
Sure this is just a "little" 302 cube push rod Ford motor.
And this is a "little" 9" blower, (same size as our P-1SC-1 and D-1SC)
Though that will make it a PERFECT fit for guys with built C6's, wanting to fit in the stock brackets, (Flip Drive Recommended) This "little" blower packs more punch then Chuck Norris on RedBull.
We know of at least one C6 CorvetteForum member getting ready to do testing with his F-1A-94
Old 10-14-2014, 03:41 PM
White_Lightning
White_Lightning's Avatar
Though that will make it a PERFECT fit for guys with built C6's, wanting to fit in the stock brackets, and run the stock drive system. This "little" blower packs more punch then Chuck Norris on RedBull.
Is there anyway to send you a PM? seems you have that function disabled and i had some blower related questions for you
Old 10-14-2014, 04:17 PM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
What do you mean by stock drive systems? As in a belt and not a crank/gear drive? A stock drive system/bracket can't even max out a d1sc, let alone a F1 blower so I'm confused on what you mean by stock drive system.
Mustangs rock. My ford runs same times as vettes with 200+hp. Solid axle FTW.
Old 10-14-2014, 04:21 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Why couldnt the stock drive system max it out?
Old 10-14-2014, 04:28 PM
Unreal
Unreal's Avatar
Slip. Every D1sc I've tried to push on the 6 rib factory setup hits ~700rwhp then can't get a belt to hold. Needs an 8 rib/flip drive.
Old 10-14-2014, 04:35 PM
nareg
nareg's Avatar
What's different between this head unit and a normal F1A?
Old 10-14-2014, 04:42 PM
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
The 94......duh.
Old 10-14-2014, 05:00 PM
0ProChargerTech
Former Vendor
A lot of time went into the all new impeller, and volute. LOTS of R&D and flow testing. The American Racing headers car, also just set a record using this new style impeller. A heavy heavy IRS car (3,600lbs) Gen 5 Camaro 7.84@176
Again, this is a P-1SC-1 sized blower going 180mph in the 1/4. It takes a good amount of HP, to run 180mph (or 176, with a 3,600lb IRS car)
(Use one of those online match calculators, and one might be shocked what a 9" blower is doing)
You will see this tech, making its way to other blowers we make over time. Though the F-1A-94 is the start.
Sorry that was a little carry over verbiage from the C7 post, however.
This has been discussed many times on here. There are a good number of CF members that have made well more then that on the stock drive system.
However, there are always options, for people that go past that.
1) Overdrive balancers.
2) Flip drives (using the stock ProCharger bracket, and dedicated belt)
There are at least a handfull of 900+ rwhp cars on here with the stock brackets, and a flip drive.
(using brands like A&A's flip drive, Cartek, and Dallas)
For this blower, We suggest its ideal for those wanting the just flat out MAX out the blower, so running a dedicated 8rib or 10rib would be ideal with a Flip drive. This blower is NOT for people wanting to make less then 900HP. If you are making less then 900HP, then the standard F-1A is for you. (More boost in the midrange)
Old 10-14-2014, 05:01 PM
0ProChargerTech
Former Vendor
All questions can be sent to ts@procharger.com
Thanks!
Old 10-14-2014, 05:06 PM
C6 Curtis
C6 Curtis's Avatar
What is the HP rating on this new blower?
-Curtis
Old 10-14-2014, 05:11 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
haha.... Hes deff not talking about a stock 6 rib setup... He just ment C6 brackets etc.
Old 10-14-2014, 05:12 PM
0ProChargerTech
Former Vendor
-Curtis
We rate it at 1,200HP. However for those that want "real" world numbers, take the two examples that I listed above, and put them into a "drag race" math calculator that takes Trap Speed, and Weight into account.
The little 302 Cube Mustang had to weight at least 3,200lbs to be class legal, and went 180mph.
The Camaro is said to be 3,600lbs by the guys at American racing headers, and went 176mph.
Just food for thought.
Old 10-14-2014, 08:13 PM
SteveDoten@ARH
Premium Supporting Vendor
SteveDoten@ARH's Avatar
This is true
__________________
FIRST C7 IN THE 9's....ARH Equipped.
631-608-1986 ext. 101
Email: steve@americanracingheaders.com
Facebook: www.facebook.com/americanracingheaders
Web: www.AmericanRacingHeaders.com
USAF/OIF VETERAN
Old 10-14-2014, 08:29 PM
Detoxx03
Detoxx03's Avatar
I want to test one
Old 10-15-2014, 02:36 AM
1sc334
1sc334's Avatar
My engine calculator came up with over 1700hp on Stang and over 1800hp on camaro. ....
Old 10-15-2014, 09:15 AM
0ProChargerTech
Former Vendor
Thats a bit high.... But, its still up there.
This blower is the end all, for a built C6, that doesn't want to have to try and cram a big blower under the hood, but wants to dominate drag and roll racing events. Imagine opening the hood at an event, people wouldn't think twice at a little blower the size of a D1SC or Novi 1500 or Vortech V1, making that kind of power.
It could be the sleeper, of blowers. LOL.
"That little guy,....don't worry about that little guy"
Old 10-15-2014, 09:16 AM
0ProChargerTech
Former Vendor
Thanks, thats what I meant. I just meant no crazy custom brackets, no cogs needed, that kinda thing.
To The new ProCharger F-1A-94 is HAULING the mail.....
Old 10-15-2014, 09:26 AM
BOO666
BOO666's Avatar
So how much
Old 10-15-2014, 09:40 AM
Mike Farris
Mike Farris's Avatar
Looks good indeed. Will there be new variants of other blowers? P, D series?
Old 10-15-2014, 10:32 AM
Slo-Poc
Slo-Poc's Avatar
D1sc might be history by the end of the year definitely would order a few pulley combos though.
Quick Reply: The new ProCharger F-1A-94 is HAULING the mail.....
