Boost gauge necessary?
I plan on installing an A&A V3 Si S/C (max 6-8 psi) I prefer to leave the interior oem. Is it necessary to install a boost gauge? If so, not thrilled to put one on the pillar. Where did you guys install one?
Dashlogic.
Or nothing. You don't need a boost gauge. Is it helpful? Can it help diagnose issues? Yes and yes, but is it needed, nope.
Dashlogic.
I second the dash logic recommendation. Thats what I run on my car with an ECS set up. Clean, no messing with install and running major wires, and out of sight.
Remember, you need a new map sensor to read boost with the dash logic, the stock map sensor only reads up to about 2 lbs of boost if I remember. You have to get the Zr1 map sensor, and have the tune changed to use the new sensor.
Dashlogic is so flexible, lets you monitor so many things and also set alarms and they are always adding new features to it. I added an Aeroforce fuel pressure sensor so I can monitor fuel pressure.
With experience I have... do NOT need one... I installed one for the cool factor and possible tuning ... when you WOT - trust me your not looking at a boost gauge to tell you what PSI your running... Your looking straight ahead and holding on...
I'm just telling it like it is man not trying to hurt your feelings... Sorry you got so butt hurt over my joking comment I made! this is the internet man all in good fun, and to reply to your statement that is far from accurate... Ahhaha good one tho LOl for a guy to make a comment about another mans dick on the internet is weak sauce, what does your slow car have to do with the size of my *****? You sound like a highly educated human being! Go back to the bushes troll :P
Supremacy 1 car at a time
